Old 07-24-2003, 12:43 AM   #1
james_gt
Member#: 20852
1995 Impreza L
Red
Default No spark in new engine!! PLEASE HELP!
My friend and I just swapped a 2.2 l into a 95 1.8. The engine is running on the 1.8 ecu. It has 2.2l block and heads with a 1.8l intake manifold. We are at our ends. The engine turns over and sounds like it wants to start. We have checked fuses and the timing belt and battery. When we try to start it we do smell a rich gas smell. Any help woould be appreciated and needed. Thanks.
James
james_gt is offline   Reply With Quote
Old 07-24-2003, 01:24 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Is the ignition coil on the 1.8L working and plugged in? Have you pulled a plug after cranking to ensure that it is indeed getting fuel? Was the 2.2 verified as working before you swapped it in? Any CELs?
-Jon
Old 07-24-2003, 06:17 PM   #3
james_gt
Member#: 20852
1995 Impreza L
Red
Yes the coil is working. The plugs smell of strong gas after we try to start it and the engine ran very well before he pulled it from his moms legacy.
Old 07-24-2003, 08:03 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Try swapping a 2.2 ecu in?
Check all your connections.
are you getting spark at the plugs?
Check and make sure you plugged in the Crank and Cam Sensors?
Jay
Old 07-24-2003, 09:39 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
A CEL would almost certainly tell you what's going on. Unless, of course, you didn't hook it up
-Jon
Old 07-24-2003, 10:40 PM   #6
james_gt
Member#: 20852
1995 Impreza L
Red
we tried all of them and we still cannot get it started. Will the 1.8 ecu work on the 2.2. We checked the ignitor box and the coil and we still have no spark.
James
Old 07-25-2003, 08:44 PM   #7
imposter
Member#: 10642
95 Impreza EJ22T
GROUNDS! GROUNDS! GROUNDS!
Check your grounds! Especially since you swapped the manifold. There is a very important ground connection at the manifold by cylinder #4. Its tucked between the fuel injector and breather hose fitting in the valve cover. I recently completed a swap and had the exact same problem and symptoms... engine ran before, strong gas smell after cranking... I thought I checked and tightened everything but this one slipped by me. I even bought a new ECU thinking it was the problem but it wasnt. I guarantee thats what the problem is. Hope this helps.
-Jim
imposter is offline   Reply With Quote
4eat tranny specialists please HELP! no 3rd or 4th gears please help!!! willyp Transmission (AT/MT) & Driveline 19 03-13-2014 10:57 PM
No spark, and i searched. Plz Help! generaltesla Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-23-2007 06:39 PM
K-A-O-S needs a new engine, please help K-A-O-S Legacy Forum 18 03-25-2006 08:32 PM
New 04 wrx with a rattling engine - please help wonny Newbies & FAQs 6 01-20-2004 04:35 PM
ticking noise in my engine. please help NoBottleWRX Newbies & FAQs 1 01-06-2003 09:08 PM
