Old 07-24-2003, 01:44 AM   #1
x12oyx316x
Member#: 14532
2002 rexakacorolla
Platinum Silver Metallic
Question rotating tires. . something weird or overworrying
i was rotating my tires today and i tried to unscrew the lugnut and my tire spun. . my car was in gear when it was raised and my e-brake was on. . this happened on all tires. . .why??
x12oyx316x is offline   Reply With Quote
Old 07-24-2003, 02:47 AM   #2
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Break loose the lugnuts with the tire still touching the ground, and you won't have that problem anymore.
drees is offline   Reply With Quote
Old 07-24-2003, 10:07 AM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
are u absolutely positive that you were in gear?
cuz if you are, then i'm just as baffled and would also appreciate an answer
vile is offline   Reply With Quote
Old 07-24-2003, 10:37 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
This is normal if both fronts or both rears are in the air. You would also notice that the opposite wheel spins the other direction. This is caused by the gears in the diffs. Completely normal.
Tim Sanderson is offline   Reply With Quote
Old 07-24-2003, 10:48 AM   #5
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
It should only do it on the front because it's an open dif (not to mention that he had the e-brake up). THe rear shouldn'y turn if you have the car in gear. The beauty of Limited Slip Differentials...
cavymeister is offline   Reply With Quote
Old 07-24-2003, 10:56 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The rear will do it too if the e-brake is not on. Neither diff is "open" they are both limited slip. the center is a viscous type.
Old 07-25-2003, 06:49 PM   #7
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
I'm pretty sure the front diff on a WRX is not limited slip. I thought that was something they just recently put on the USDM STi. Could be wrong. Anyways, limited slip or not, there is not enough force from spinning the wheel by hand to get the diff to lock up. Always loosen lugnuts before jacking. Heck I was told that in high school drivers ed.
Keith99RS is offline   Reply With Quote
Old 07-26-2003, 09:10 PM   #8
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
MY 02-03 2.5 RS - no front lsd - no rear lsd
MY 02-03 WRX - no front lsd - rear VLSD
MY 04 STi - mechanical front lsd - mechanical rear lsd
oh and Keith is right!
Dan
Merdock777 is offline   Reply With Quote
Old 07-27-2003, 10:46 AM   #9
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Just make sure when you loosen the lug nuts while the car is on the ground, you just break the lugs loose. I guess you can't assume the obvious can you ?
-Charles-
ImprezaVA is offline   Reply With Quote
My name is awkward or how a mother-to-be shouldn't name their child something weird. Super Nintendo Off-Topic 336 03-01-2013 12:46 PM
Something incredibly sad yeilds something weirdly SUPER AWESOME markman Off-Topic 11 02-28-2008 05:20 PM
so i was washing my car when i notice something weird!!! akcel Member's Car Gallery 28 10-22-2001 02:47 AM
('93-'01) Im hearing something weird from my engine whenever I blip the gas S-WRX Impreza Forum 8 09-18-2001 05:58 PM
Want to know something weird about removing the bumper vent? Swivel1000 Normally Aspirated Powertrain 17 03-06-2001 06:14 AM
Message Board Statistics All times are GMT -4. The time now is 01:20 PM.
