Old 07-24-2003, 03:31 AM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Default Engine buildup (question for pros)???
I want make a engine buildup but with a small budjet and i have 2 or 3 question for you pros?!?!?!
I will start with my RS-T how run very well for now at 8psi. It have T3T4 turbo + piping , fuel pump, stock injector, WRX TMIC, 2.5 cat/back, RRFPR, COBB CAMS, Borla headers, and more.
-Goald, 99 2.5L sohc runing 13 to 14psi and 75hp to 100hp NOS.
-I do not have the money to buy a stand-alone and RC injector for now so, i have to use a ITC, a S-AFC and 420cc WRX injectors.
QUESTION:
1-Should i get a set of 9.7@1 forged J&E piston, and keep my low end torque or get 8.5@1 forged J&E piston? Will i get the same HP at the same boost with the 9.7 and the 8.5??? Do you think the engine will easier to set with the 8.5???
2-Do you think the ITC and a S-AFC will be able to drive 13psi of boost or more and how much???
3-How much boost do you think i can go with the 420cc wrx injectors? Do you think i will have to use a RRFPR wtih them???
4-Do you think i have to go close deck or should i save my money to get a good set of ported head???
Thanks for your help in advance.
Sorry for my english i am french
More question to come
JST is offline   Reply With Quote
Old 07-24-2003, 06:57 AM   #2
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Flirting with danger is what comes to mind.
Honestly though, you may want to rethink the idea of going for a 14-15psi buildup of a 2.5 if "limited budget" is anywhere in the plans.
Unless you can do a very good tuning job yourself, the costs of that alone may prohibit it.
ShadowIMg is offline   Reply With Quote
Old 07-26-2003, 02:51 AM   #3
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
No body can give me more info???
Please need help!?!?!?
Old 07-29-2003, 10:10 AM   #4
jin88
Member#: 29784
I second that, to run more boost and be safe, there is no cheap way of doing it unless you just get a great deal on some parts. You are going to want more fuel plan and simple. If I was you, I was just pass on the 440 injectors and get 550cc injectors b/c they are not that much more. "for a example."
I don't want to see your car up on the forum with something that blow! Just save your money and do it right the first time b/c if you do it half-ass, you are going to want more power down the line and will have to buy stuff all over again.
jin88 is offline   Reply With Quote
Old 07-29-2003, 11:18 AM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Danger Danger....
1. Get the Forged J&E Pistons. If not now, you will need them later when you turn the boost up..
2. No... atleast, not safely and could eventually cause you to have to do #1 if you don't at the start.
3. Guess about 12 - 15 psi before you hit 90% IDC.
4. Neither. Just get springs + retainers and a a good set of cams.
BTW, make sure you have plenty of money to piss away, because that's what you'll be doing...
kastle is offline   Reply With Quote
Old 07-29-2003, 03:52 PM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Also, I wouldn't recommend doing what you want to do without and engine management system. There is just going to be too much happening for a simple ITC and SAFC to a good job.
Graham
Graham is offline   Reply With Quote
Old 07-29-2003, 04:40 PM   #7
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
OK..
1) Look Look !!
sorry...
2)No, I'd recommend standalone at that high boost...
3)What Kastle said..
4)Again....whats been said.
Wedge is offline   Reply With Quote
engine swap questions for a 94L Homemade WRX Subaru Conversions 6 09-30-2007 03:12 PM
Engine Internals question for the Gurus. BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-06-2006 11:59 PM
Seriously considering my options for a RADICAL ENGINE BUILDUP. BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-09-2002 10:55 AM
Engine buildup DOHC or SOHC jetfan8178 Normally Aspirated with bolt-on Forced Induction Powertrain 14 04-11-2002 03:55 PM
Ton's of engine swap questions for you Gurus Eric SS Normally Aspirated Powertrain 4 09-27-2001 10:46 PM
