Old 04-24-2001, 01:04 PM   #1
JohnWad
Member#: 4768
2002 WRX Sport Wagon
Post
They look a lot like GoFastBits BOVs. The price listed is not a good as the GB that we got direct for the WRX specific BOV, not bad though.
JohnWad is offline   Reply With Quote
Old 04-24-2001, 01:19 PM   #2
p7r4e7y
Member#: 4261
wrx srp
sm #747 sd region
Post
i ordered one from alamo motorsports that is comming from turbo xs. i hope they send me the right one. they were finalizing insatll instructions on monday.
p7r4e7y is offline   Reply With Quote
Old 04-24-2001, 01:46 PM   #3
[ /dev/null ]
Member#: 3998
Question
why buy from Alamo? You should support the local subbie-specific tuners. Check out www.cobbtuning.com. Trey is a really nice guy and can help you with ALL of your WRX needs.
peace,
shawn
[This message has been edited by [ /dev/null ] (edited April 24, 2001).]
[ /dev/null ] is offline   Reply With Quote
Old 04-24-2001, 02:51 PM   #4
Bob Cant
Member#: 5763
02 WRX & EVO6 &TTT
All blue
Post
I am going to order mine from Stratmosphere
Bob Cant is offline   Reply With Quote
Old 04-24-2001, 02:58 PM   #5
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Smart ForTwo
Post
I hope that the Cobb page is updated soon with WRX info and prices.
Leo
Leonardo is offline   Reply With Quote
Old 04-25-2001, 12:38 AM   #6
Opie
Floresbian
Member#: 470
2013 BRZ, 2011
Forester, '04 Chev 2500HD
Post Blow off valves for the new WRX
Check them out here .
Opie is offline   Reply With Quote
Old 04-25-2001, 03:12 AM   #7
Adrian128
Member#: 3346
2001 WRX Wagon
Post
Man.. those look like the Turbosmart BOVs that we have here in Australia. Maybe they have a different name in North America. If they are they are cheap POS. I mean.. how many BOV give a loud psssssshhh sound when lifting off at 2500 rpm?
Turbosmart
[This message has been edited by Adrian128 (edited April 25, 2001).]
Adrian128 is offline   Reply With Quote
Old 04-25-2001, 04:43 AM   #8
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
Post
OK, some dumb questions are in order. All this talk of BOV's, but what I'm not hearing is what results anyone is getting from installing one. I would assume the main reason is to keep the turbo spooled up between shifts when you're off the throttle? Is there any other another reason for installing one?
Can you vent to the atmosphere or do you need to keep it a closed system?
I'd really like to hear some firsthand impressions on how much this will improve things. Can you actually feel a seat of the pants difference?
harrydog is offline   Reply With Quote
Old 04-25-2001, 05:57 AM   #9
p7r4e7y
Member#: 4261
wrx srp
sm #747 sd region
Post
this is why. as far as other stuff (new turbo) ill see trey.
Old 04-25-2001, 06:19 AM   #10
GRWRX
Member#: 4129
2002 WRX sedan
Post
I feel the same as harrydog. What gains are had with an aftermarker BOV? If anyone has one installed, what's your experience?
George
GRWRX is offline   Reply With Quote
Old 04-25-2001, 07:56 AM   #11
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Post
I owne a ZEN bov. As far as what a bov does, there has been some debate. What I understand is that they vent excess pressure when you let off the throttle. Some people, like me, like the sound they make when vented to the atmosphere. Supposedly venting in this way helps reduce spool time when thrttle is reapplied. Maybe it prevents compressor stall? Some people have the vents routed back into the air stream between the turbo, and the throttlebody.
I can tell you that venting to the atmosphere seemed to allow boost to build more quickly. But, since I was venting pressurized air, maybe that's not so good, in hindsight. Once the throttle is reopened, that pressurized air can be put to work as "boosted air" that's already available, rather than having to build more boost from a lower pressure level. If the bov is on the outlet side of the intercooler, that might mean that cooled charged air is rerouted to the intercooler inlet, thus lessening the work load on that unit. My unit was mounted before the inlet unit, and one could feel the heated air at the bov vent when it opened up.
IN SUMMATION: I probably won't get an aftermarket bov unless it's mounted on the intercooler outlet, and only then if it replaces the stock unit (if that unit is mounted on the inlet side of the intercooler). I ould then not vent that cooled charge to the atmosphere. I think bovs can be "hype" acessories if they mount on the inlet side. Here's another observation. If the bov is mounted on the outlet side, there would be a nice adiabatic effect for the intercooler. This means that a pressure drop is attended by a temperature drop (why cold beverages freeze, if close enough to freezing temperature)when opened. This means the intercooler would drop a few degrees in temperature, and so become a bit more efficient in cooling the next boost charge. That's how I see it. I used to work as a plant operator in a liquid nitrogen plant, and I know just a few psi pressure drop can drop the temperature of a liquid enough to have a desired effect.
sorry to be long. Anyone else know if bovs are hpe gadgets, or useful aftermarket tools?
darryl
Darryl is offline   Reply With Quote
Old 04-25-2001, 08:16 AM   #12
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Wink
by the way, I did a couple of searches: "what blowoff valves do", blowoff valve". interesting info, still no definitive. [url=http://www.audiworld.com/bbs/a4/984/messages/1472.shtml]
Old 04-25-2001, 10:24 AM   #13
GDA
Member#: 4324
02 GDA
Platinum
Post
I am using a Hybrid BOV from GFB in Australia.
The unit is of the highest quality and finish. This unit blows back into the stock system as well as to the atmosphere.
This BOV has the option of running full open atmosphere when the time is right or when the user chooses to do so.
Besides the "cool" sound, although not as loud as some of the japanese BOV's, i notice under hard acceleration there is better response from the car.
The GFB hybrid was a direct bolt on affair, and was purchased from www.mrtrally.com.au for $175 USD plus shipping. I would strongly suggest people ordering some other stuff to making shipping worth while. I under up getting the BRAKE MASTER CYLINDER SUPPORT, and a set of DBA XDRILLED and SLOTTED rotors, same ones that ISR sells on their site.
I am very happy with my products. There website has a whole bunch of stuff so look carefully and try to make on large order (not physically).
So far there has been no negative feedback from the car after BOV installation, as far as full open atmosphere is concerned i have no idea.
EJ20WRX
GDA is offline   Reply With Quote
Old 04-25-2001, 11:21 AM   #14
[ /dev/null ]
Member#: 3998
Post
Trey is a REALLY busy guy, even though he doesnt have updated prices on his webpage does not mean he does not have the parts. Just give him a call.
peace
Old 04-25-2001, 10:29 PM   #15
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
EJ20WRX,
I just ordered the same one as you from Irvine Subaru but also talked to Marcus at MRT. He stated that gas mileage was poor if you run full atmosphere. Have you tried running full atmosphere yet? I'm curious as to how poor the gas mileage gets.
blkwag is offline   Reply With Quote
riverside ca Gfb Blow Off Valve For The Wrx & Sti Von Pierre Engine/Power/Exhaust 3 10-11-2007 01:23 PM
Best turbo timer an blow off valve for a 98 wrx impreza wagon veilside2121 Newbies & FAQs 6 12-27-2006 09:25 AM
SOCAL: Blitz Dual Drive Blow-off Valve for 2002+ Subaru WRX/STi ILSMKU2 Private 'For Sale' Classifieds 13 04-26-2006 04:25 PM
**BLOW OFF VALVES FOR THE STi** STiVTEC Factory 2.5L Turbo Powertrain 13 08-17-2004 02:47 PM
Universal Blitz Blow off Valve for the 2002 WRX andivic Factory 2.0L Turbo Powertrain 3 06-15-2001 10:47 PM
Message Board Statistics All times are GMT -4. The time now is 06:12 AM.
