Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 07-24-2003, 10:31 AM   #1
Forsa
Member#: 24378
Default Engine Builders: head cc's and deck height
Any help from you engine builders out there would be appeciated.
Doing the final math on my EJ25 build and need:
- the Deck Height for the EJ motor
- the cc volume of the stock WRX heads
Also, if you have put WRX heads on an EJ25 short block, what head gasket did you end up going with (ie. which model engine/head)?
Thanks guys for helping out. This forum is excellent!
Fin
Forsa is offline   Reply With Quote
Old 07-25-2003, 11:03 AM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
You would need to use the EJ25 head gasket to accomodate the larger bore size of the EJ25....
latinskllz is offline   Reply With Quote
Old 07-30-2003, 12:13 PM   #3
Forsa
Member#: 24378
Default Help
With all these Subaru Guru's here and no one knows this information?
Please help me out if you know the above, I really need this to conclude my project.
Fin
Old 07-30-2003, 12:27 PM   #4
8Complex
Member#: 922
04 FXT
Red
My calipers only go up to 6", otherwise I'd be able to measure the deck height for you. It's at least 9", though.
Old 07-30-2003, 12:38 PM   #5
Forsa
Member#: 24378
Default Got it!
Great news, the guys at JE Pistons are rock stars! Thanks to them we have the information. In an effort to share here it is:
02-03' WRX engines:
CC's of heads = 48cc
Deck height = 7.913" (201mm)
Thanks guys and hope this helps other engine builders.
Fin
Old 07-30-2003, 01:01 PM   #6
8Complex
Member#: 922
04 FXT
Red
Interesting... I wonder why they picked 402mm as the width for all the EJ-series motors.
Old 07-31-2003, 12:55 AM   #7
markus
Member#: 438
2004 STi
White on Gold
Anyone have the same info on the N/A EJ25 motors?
markus is offline   Reply With Quote
Old 07-31-2003, 01:40 AM   #8
8Complex
Member#: 922
04 FXT
Red
The deck height will be the same, the head volume depends on which head.
Deck Height/Quench Height/Rod length MartinSTi05 Built Motor Discussion 32 04-05-2011 09:50 AM
Head gaskets, deck height, CR and valve notching iswinkels Factory 2.0L Turbo Powertrain 2 01-04-2006 11:39 AM
$1400 95 STi-RA version 2 engine, $900 heads, $500 ej20g solid deck shortblock forged supermoose Private 'For Sale' Classifieds 1 09-06-2005 03:41 PM
Engine Builders: head cc's and deck height Forsa Factory 2.0L Turbo Powertrain 3 07-24-2003 10:30 AM
Question for the Subaru engine builders: Cobb Tuning, B Spec USA, Rallispec, et al. Digital_Boy Normally Aspirated Powertrain 0 01-31-2001 03:13 AM
