Old 07-23-2003, 07:28 PM   #1
Boost4U
Member#: 16459
1998 2.5RS
Default RS 4EAT to WRX 5MT swap....?
This is what I am doing at the moment, I was jsut wondering if anyone knows how the two connectors on the clutch pedal lever can be wired into the car so that the car can eventually be started with the clutch depressed? I'm not sure why there are two clips?? Oh yeah......I have a 5MT pedal set from a 2000-01 RS.
I'm a little lost guys....help me out?
Cheers,
- Chris
Boost4U is offline   Reply With Quote
Old 07-24-2003, 07:30 AM   #2
Kha0S
Member#: 8808
DGM 5D
There's a wire on one of the transmission harnesses that is wired into the starter circuit that notifies the car that it is in park and/or neutral.
This wire will need to be shorted in order for the starter circuit to fire.
I just shorted it directly instead of making it dependent on the clutch pedal, so I can start the car without pressing in the clutch -- arguably a feature to help prevent axial load on the motor on a cold start.
Just takes a little more diligence to make sure you're not in gear when you start up.
/Andrew
Kha0S is offline   Reply With Quote
5eat to 6mt/5mt swap questions. (05+ LGT) crrider80 Legacy Forum 11 08-01-2011 04:44 AM
'98 RS 4EAT to 2000 RS 5MT w/ LSD keirnna Subaru Conversions 100 10-22-2009 12:25 AM
THE RIGHT ANSWER?? Rs 4eat vs. Wrx 4eat? scurabus Transmission (AT/MT) & Driveline 2 04-05-2009 07:46 PM
Auto RS to WRX 5MT tranny? Scott_2.5TS Subaru Conversions 5 12-05-2008 11:51 AM
Any shops in the NY area that can perform a 4eat to 6MT sti swap?? Alan l. Tri-State Area Forum 6 09-11-2007 09:50 AM
