Old 07-24-2003, 01:44 PM   #1
modvp
Member#: 25215
Default How many of you with aluminum control arms on your WRX
have you noticed a big difference in control and stability?
modvp is offline   Reply With Quote
Old 07-24-2003, 02:19 PM   #2
kenchan
Member#: 15106
for the street, i think the factory one works just fine.
kenchan is offline   Reply With Quote
Old 07-24-2003, 06:19 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i have the alu control arms and bushings that come with the SPT kit and they feel more precise. i installed each part of my SPT kit in piecmeal so the difference with the control arms was in fact noticeable. things just felt more controlled, precise... hard to describe but i like it.
nhluhr is offline   Reply With Quote
Old 07-24-2003, 07:15 PM   #4
modvp
Member#: 25215
nhluhr;
you noticed a difference with the forged alunimum arms, with the stock shocks and springs?
Old 07-24-2003, 08:50 PM   #5
BIGSKYWRX
Member#: 7958
09 GH B+
I have aluminum control arms recently added (earlier than planned ) to my STi RA setup, cornering is more precise- likely due to less deflection in the arms vs the oe stamped steel ones. Some people think there are weight savings due to the aluminum build, but the aluminum ones are only 1/4 lb lighter. What is amazing to me is these lovely pieces cost the same as the oe stamped ones.
Big Sky
Old 07-24-2003, 09:06 PM   #6
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Thumbs up
Yep same fr me except i added them to the STI reg takeoff setup(struts, springs, tops),,i like em.It's the little things that add up to a total package.
Rudy
jagcars26 is offline   Reply With Quote
Old 01-02-2004, 03:17 AM   #7
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
-bumping from the dead-
Those of you who liked the arms - did you isolate the arms from the bushing install? Now that the arms are legal in STX, I have been thinking about them, but I don't want to go through the pain of installing all the wacky bushings if possible..
thanks!
john
Old 01-02-2004, 08:53 AM   #8
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
Well, if you buy the aluminum arms, they come with the STi bushings installed already.
-Keith-
CTKAG is offline   Reply With Quote
Old 01-02-2004, 10:34 AM   #9
BIGSKYWRX
Member#: 7958
09 GH B+
thanks!
john
They are lgal for STX now? Could you point me in the right direction to see that.
Thanks.
BTW they do come w/ firmer bushings (and a new ball joint!), but I am thinking that the Group N ones, may be firmer yet. Evidently that was the case w/ a few bushings in the STi, ie lateral links-firmer than WRX, but not as firm as the Group N ones. I don't think this has ever been proven beyond a shadow of a doubt, but possible.
Big Sky
Old 01-02-2004, 10:43 AM   #10
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Thanks.
Big Sky
Yes, please find me the rule stating that Alum control arms ARE leagal in STX. If that is so.. I am going to run STX this year!
My car came with the STi/SPT v7 kit, so I will have to say that I love the steering response. However, I have had it since day one, so I really cant comment on difference.
However, let me know about the STX rule... I still dont think it is allowed, and I believe it bumps you all the way up to SM.
dowroa is offline   Reply With Quote
Old 01-02-2004, 11:00 AM   #11
BIGSKYWRX
Member#: 7958
09 GH B+
I did some digging and it appears control arm changes are legal, but w/ a caveot- you can only choose one form of camber change ie if you use camber plates, control arms aren't allowed to be changed modified. I posted a question as the STi control arm does not effect camber, if one could still run camber (oe camber/caster plates) as I am.
If you have no additional camber changes, your SPT setup would be fine.
Unfortunately for me- my Noltecs allow me -2.2 camber and 4.8 caster so I won't be giving them up. I'll post a clarification when I get it.
Big Sky
Old 01-02-2004, 12:02 PM   #12
ConeMasher
Member#: 2135
There's nothing unfortunate about -2.2 camber and 4.8 caster
Except maybe that it's not -3.0 camber!
-- Gary
ConeMasher is offline   Reply With Quote
Old 01-02-2004, 01:37 PM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
-- Gary
So very true! I just need to get over the fact that I'm in a new class
Big Sky
How many of you have done OS tune's on 2010 WRX's? josserman Open Source Reflashes 6 03-19-2010 01:58 AM
Honestly, How many of you actually watch the WNBA on a reg basis? brucelee Off-Topic 7 09-13-2007 08:45 PM
How many of you guys went from RS-T to wrx swap? cRayZee Normally Aspirated with bolt-on Forced Induction Powertrain 36 10-18-2004 11:54 AM
Rolling off of fishguys thread. How many of you still hold a candle form your first? Wheels Off-Topic 47 12-11-2002 10:04 PM
