Old 07-24-2003, 02:14 PM   #1
x12oyx316x
Member#: 14532
2002 rexakacorolla
Platinum Silver Metallic
Default my jack points failed EDIT *PICTURES!!
i was jacking up my car on all 4 sides and the jack points failed. . they basically totally shattered except for one corner. . .i can still jack the car up on that spot without damaging anything else. . but why did my jack point just shatter like that?
x12oyx316x is offline   Reply With Quote
Old 07-24-2003, 02:21 PM   #2
twitch
Member#: 15954
2002 WRX Sedan
Hey...one of mine FODed out on me too. Luckily I got the painted sideskirts & they covered the area up so you can't see it unless you get down & look under the car. I still use the jack in that spot & haven't had any problems.
twitch is offline   Reply With Quote
Old 07-24-2003, 02:21 PM   #3
kenchan
Member#: 15106
were you using the factory jack or a hydrulic jack?
if factoryjack, you need to slip the jack point into the slit of the top of the jack. are you sure it was the entire jack point that "shattered" and not part of the side skirts?
kenchan is offline   Reply With Quote
Old 07-24-2003, 02:37 PM   #4
x12oyx316x
Member#: 14532
2002 rexakacorolla
the side skirts had no visible damage on it. . just the jack point. . i used a hydraulic jack and that also had slits on the top of the jack and i made sure it fit well into the jacking point. . as i was pumping . . BAM. . it seemed like the jack slipped off but the point just shattered. . what can i do. . eh
Old 07-24-2003, 04:37 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Im interested in seeing an image.
Old 07-25-2003, 01:03 AM   #6
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
ditto
biggreen96 is offline   Reply With Quote
Old 07-25-2003, 01:36 AM   #7
x12oyx316x
Member#: 14532
2002 rexakacorolla
i'll take some pictures of it later today. . .it's kind of funny and sad at the same time. .
Old 07-25-2003, 02:08 PM   #8
biggreen96
Member#: 12535
vf39 06 5MT XT
like a dead mime
Old 07-25-2003, 02:42 PM   #9
x12oyx316x
Member#: 14532
2002 rexakacorolla
here it is. . .it's like this to 3 sides out of 4 and there is significant damage to the side skirts as you can see in this pic. .
Old 07-25-2003, 03:12 PM   #10
x12oyx316x
Member#: 14532
2002 rexakacorolla
ok i guess that doesn't work. . .i'll try again after work
Old 07-25-2003, 04:09 PM   #11
biggreen96
Member#: 12535
vf39 06 5MT XT
Old 07-25-2003, 05:13 PM   #12
blackbok
Member#: 12176
2002 Geo Metro
Teal
Front crossmember and rear diff. Those are the jack points that won't crush.
blackbok is offline   Reply With Quote
Old 07-25-2003, 06:08 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
Thats what I thought
Im trying really hard not to be mean but dangit, you deserve what happened.
The proper jack or stands will be slotted. It has been posted MANY times on this forum how to get around the problem.
The cheapest method was to get a 2x4 and cut a slot.
Old 07-25-2003, 06:46 PM   #14
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Are the jackpoints made to hold the entire weight of the car on 4 separate points? That's a lot more weight than would be on the jackpoints for just changing a tire.
Keith99RS is offline   Reply With Quote
Old 07-25-2003, 07:36 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
Keith99RS: The issue is not the weight, its that all the weight was put onto the seam, NOT the jack point itself.
Old 07-25-2003, 08:05 PM   #16
kenchan
Member#: 15106
holly crap! first time seeing THAT!
Old 07-29-2003, 02:20 PM   #17
leecea
Member#: 37359
2003 WRX
Yuk! Mashed metal!
This is totally confusing me because I just read through a thread in this forum with a number of people advising to put the car on four stands, one at each factory jack point, when you want the whole thing in the air. In fact, I've seen this advice many times in other threads too. But I've also seen the comments about jack points collapsing.
I've tried a few places for stands and the jack points sure are convenient, especially for the rear where I don't see any obvious alternatives. I've also tried to figure out how to use a slotted 2x4 or hockey puck (suggested in another thread) on top of a jack stand but all the options look way unstable. I even thought of sawing slots in the tops of each stand but that seemed like an accident in the making.
Is it just pure luck as to whether the jack points hold or not? If you don't use the jack points, where the heck do you put the jack stands for the rear?
leecea is offline   Reply With Quote
Old 07-29-2003, 04:09 PM   #18
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
Wow, I guess I won't be using those jack points anymore with my hydro jack. I didn't realize they were that fragile.
ha-evolution is offline   Reply With Quote
Old 07-29-2003, 06:14 PM   #19
Forblue
Member#: 27865
Check out Eastwoodcompany.com for a floor jack saddle replacement that will fit those jack points. Saw that from another post a few years ago.
RickH
Forblue is offline   Reply With Quote
Old 07-29-2003, 07:36 PM   #20
ciper
Member#: 15543
90BJ Legacy LS ABS
Dangit, you guys!
THE SEAM IS NOT THE JACK POINT. ITS THE AREA ON EITHER SIDE OF THE SEAM THAT IS THE JACK POINT
When using the correct jack/stand or a slotted spacer the vehicle will be totally stable. More so then when on the wheels as a matter of fact, no chance of rolling or moving up and down.
Old 07-30-2003, 12:28 AM   #21
x12oyx316x
Member#: 14532
2002 rexakacorolla
ok. . that just confused the hell outta me. . .this is what that area looks like to me. .
_____-------------__ (Wheel) <------- Rear
now i jacked on the dotted line thinkin it was the jack point cause all 4 sides have this pattern. . .so you're saying that i should jack the solid lines (underscore)????
Old 07-30-2003, 01:05 AM   #22
ha-evolution
Member#: 31556
15 STI WRB ordered
Look at how your factory jack is slotted and you will see how it is supposed to work.
Old 07-30-2003, 11:24 AM   #23
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Ummm... duh. That isn't a jack point. Like the guy said up above, the jack point is the area around those seams, not the seam itself.
Did you really expect to support a 3000lb car on an area smaller than a pencil is wide? Look at your factory jack and you'll get a better idea.
heffergm is offline   Reply With Quote
Old 07-30-2003, 01:20 PM   #24
Austin
Member#: 7089
2016 STi
On the bright side, you really didn't cause any damage. Yeah, so the metal is a bit munched... so what.
Austin is offline   Reply With Quote
Old 07-30-2003, 10:06 PM   #25
Die Civic
Member#: 3301
2001 RS
I'd hate to kick a dead horse, but yeah you missed the 'jack point' by a few inches. That's just a pinch weld, the jack point is a little further in, looks sort of like 'rail guards' on skate boards. Don't know if that was much help, don't even know if skateboards still have rail guards. Any Vision boarders on here?
Die Civic is offline   Reply With Quote
Jack stands and jack points skittle Vancouver Impreza Club Forum -- VIC 13 08-24-2009 11:38 PM
Nervous about jacking the car up at front jack point BlackoutWRX Newbies & FAQs 10 10-27-2006 11:14 PM
('93-'01) Jacking points??? 2yLiTe Impreza Forum 2 05-28-2001 08:21 PM
Jack point not a "hard" point blaster88 Technical Forum Archive 5 08-02-2000 08:16 AM
