Old 07-24-2003, 04:17 PM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Default turbo mod's?
I was thinking about what kinda mod's can be made to a turbo. All I really know so far is taking of the exauhst side and having it ceramic coated. is there anything else? what about having the air inlet smoothed out? it's kinda got some ridges on it. Can I have the compressor housing honed? or would that be a waste? also if there are some things to be done to it, could I take most of it apart myself?? Or should I leave it to a pro? Like could I take it apart to have it ceramic coated? Thanks in advance.
Courtney
9 is offline   Reply With Quote
Old 07-24-2003, 05:39 PM   #2
smacksube
Member#: 4067
01 2.5 rs
you can have both sides ported, polished, honed whatever. you can have the blades clipped for faster spool but less top end. what kind of turbo do you have...cuz it would be pointless to do all this to a wrx turbo while using it on a 2.5 cuz all the money spent on a small turbo would be money well spent on a larger turbo which will be faster in the long run.
smacksube is offline   Reply With Quote
Old 07-24-2003, 05:47 PM   #3
Mancini
Member#: 20726
Most common mods are porting and clipping. Clipping will increase power up top do to lower back pressure, but slow spool up slightly (less turbine to turn). (opposite of what smacksube said) Clipping is good for drag turbos or big power. Not recommended for autox. Obviously porting will just give better flow.
Lastly, if you have an internal wastegate you can get a larger flapper to help control over boosting.
Mancini is offline   Reply With Quote
Old 07-24-2003, 05:53 PM   #4
Mancini
Member#: 20726
You can easily take the turbine housing off. In fact you have to if you clock the turbo. But unless you know how to port I'd pay and get it done by a pro. Shouldn't cost you too much. There is a guy around where I live that will port and clip DSM turbo's for maybe 120-150. As for taking apart the rest of the turbo...I wouldn't recommend it unless you have a way to balance it.
Old 07-25-2003, 04:33 AM   #5
smacksube
Member#: 4067
01 2.5 rs
whoops..good call on the clipping...my bad
Need Turbo Help!!!!!! 07subywrxtr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-05-2010 04:52 AM
Are there any free/real cheap mod's that can be done to 2001 2.5rs coupe? 2.5rsracer General Forum Archive 13 03-09-2001 11:21 AM
Mod's for my impreza HydeX General Forum Archive 15 09-29-2000 01:38 AM
Mod's for the stock MY02 North America impreza WRX goten General Forum Archive 9 08-24-2000 09:31 PM
