07-24-2003, 04:32 PM | #1 |
Member#: 33494
Need Major Help Quick Please!
HELP!, i tried installing the indiglos, they worked, but now my radio lighting is mesed up, the HVAC and the radio button lights r not working at all! but the led screen only works when the light handle on the steering wheel is in the OFF position? what do i do, this may sound kind of stupid, but my dad is coming homein an hour, and if he sees iv been messing with the car, he is going to be SOOO pissed. thanks
07-24-2003, 05:55 PM | #2 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
Exactly which wires did you touch or splice into when you installed the indiglos? If you spliced into any of the illumination wires, remember that the Subaru uses a "reverse" illumination voltage system: when the dash light dimmer is down low, the voltage is high, and when the dimmer is at max, the voltage is down low. The illum wire that doesn't change voltage is at +12V, not ground as in a "normal" system. Perhaps your indiglos are set for a "normal" system, and you just wired them into the Subaru system thinking it worked the same way? If that's the case, just remove the indiglos, restore everything how it was, and get ones that are set up for the "reverse" lighting scheme.
07-25-2003, 12:42 AM | #3 |
Member#: 33494
hey, sorry for wasting everyones time that read this, thanks armand alot for replying. im so dumb...the dim switch on the headlight/turn signal handle was all the way down. haha i took everything out,, and it still wasnt working, then i said HEY, my mother ****ing dim switch is down. thanks.
I Need Help Quick Please | 2002whitewrx | Service & Maintenance | 3 | 04-23-2003 12:57 PM |
someone help quick please major prob | 2002whitewrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 04-20-2003 09:07 PM |
Need Help Quickly Please! | P03w | Interior & Exterior Modification | 5 | 12-05-2002 01:10 PM |
I Need Help Quick, Please!!!! | Dirty B | South East Region Forum | 3 | 09-03-2002 09:32 PM |
('93-'01) Need HELP quick please... | kaos200 | Impreza Forum | 2 | 04-21-2001 08:22 AM |
