Old 07-24-2003, 07:52 PM   #1
sovereignmk1
Member#: 11858
1998 Silver Legacy
Default E82 questions
I have a 86 GL wagon and recently the oil pressure guage has been moving from the top and bottom, staying at 85psi then dropping to 0. More recently staying at the bottom reading 0. Needless to say I'm concerned for the commuter wagon, though the engine still sounds ok (doesn't mean everythings ok though).
Side note -- It has been close to or over 100 degrees lately (checked coolant, it's good)
Any Ideas?
//M
sovereignmk1 is offline   Reply With Quote
Old 07-25-2003, 03:58 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
It is common on the EA82 for the Oil Pressure to drop to 7 - 10psi at idle when warmed-up. You are probably seeing the higher pressure when the engine is revved or cold though you did not say. You may want to stick with a thicker oil in the summer temps (30wt, 20-50). As long as you have no lifter noise or lower end noise you should be ok though.
If however, the pressure is varying with no change in engine temp or speed, I would suspect the OP sending unit or gauge.
SubyTechMaster is offline   Reply With Quote
Old 07-25-2003, 04:57 PM   #3
sovereignmk1
Member#: 11858
1998 Silver Legacy
It's mostly once the engine has warmed up, the needle is pointing to 85 or sitting below zero, occasionally moving in-between the two. It used to sit @ 45psi when warmed up and everywhere I went (local runs or highway speeds). It only moved(up a little) between shifts near 3-4k rpm, but that was before the engine warmed up entirely. Is replacing the OP sender a job a DIYer with limited knowledge could do? Thanks.
//Mark
Old 07-25-2003, 05:43 PM   #4
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
The OP sending unit is easy to get to, it's on the Oil Pump at the front of the motor. It is a pipe thread so you need to coat the threads of the new SU.
Old 07-26-2003, 07:21 PM   #5
sovereignmk1
Member#: 11858
1998 Silver Legacy
Should I change the oil (ie empty the oil, put SU on, Refill oil) so it doesn't leak everywhere? Also, Coat the threads with........ Thanks!
//M
Old 07-26-2003, 07:31 PM   #6
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
You may get some oil leaking out of the passage but you cannot avoid that even if you drained the oil pan and filter. It will not be much volume.
Coat the threads with a pipe thread compound such as Teflon Tape. The threads are tapered and if you over-tighten the SU you could crack the housing.
Old 07-26-2003, 11:54 PM   #7
sovereignmk1
Member#: 11858
1998 Silver Legacy
Thank you much Jedi Master!
//M
FS IL: E82 parts awgrimm 'Old School' Subaru Forum 0 01-16-2007 03:55 PM
2 questions- 1) sti sb question 2) bigger turbo question legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-23-2005 05:43 PM
Questions, questions questions jwineo Normally Aspirated Powertrain 8 10-06-2002 03:35 AM
Just Bought My WRX !!! Questions...questions...questions.... TheNookie Rocky Mountains Impreza Club Forum -- RMIC 10 09-27-2002 07:35 AM
Questions questions questions... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 16 04-08-2002 10:08 PM
