07-24-2003, 10:31 PM | #1 |
Member#: 12863
Vehicle:2002 2.5RS |
Gas gauge problems
My dad has a 2000 Legacy and lately the gas gauge has been acting up. The fill up light comes on and stays on for a while and then goes off when there is over 1/2 tank of gas. Then today the gas needle goes from half to below E to 1/4 to 1/8 to 1/4...etc.
I was curious if this was a sensor issue or electrical issue. Since they are both doing it it would seem to be to be electrical since I think the light and gauge use different sensors. Any help would be great
07-25-2003, 12:39 AM | #2 |
Member#: 12863
bump
07-25-2003, 03:28 PM | #3 |
Member#: 36593
Vehicle:2003 Wrx Wagon Silver |
How much is in my tank???
it can be due to temp changes or pressurization of the tank, for the flux for 1/8 to 1/4. but the warning light lighting up with above 1/2 a tank is not a good sign , it could be as simple as a loose connection but you are right it's definately electrical.
Mike |
07-25-2003, 03:37 PM | #4 |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
Have it checked by the dealer
Had a my95 impreza that had a fuel gauge problem once. Didn't light up the "empty" warning light, but the reading was inconsistent. Dealer checked it and iirc, the fuel gauge sender unit had to be replaced. If you have the factory service manual, perhaps you can at least check whether the sensor gets the right amount of input signal, perhaps the wiring has deteriorated, or there is some temporary loss of contact somewhere.
07-25-2003, 10:17 PM | #5 |
Member#: 12863
It has been pretty hot lately...more than normal so that could explain some of it. Unfortunatelly he just went out of warranty about two months ago
04 STI gauge in 03 WRX- gas level problem | TommyWRX | Electrical & Lighting | 3 | 02-02-2008 05:43 AM |
Gas Gauge Problem !!! Help ? | rutuner18 | Electrical & Lighting | 0 | 03-07-2007 11:34 PM |
1995 Impreza gas gauge sending unit problem? | SubaruImpreza_power | Newbies & FAQs | 8 | 09-24-2003 08:34 PM |
Problem with gas gauge in STi... | WRX-1977 | STi Forum Archive | 22 | 07-07-2003 08:54 PM |
Problem gas gauge or not to worry? | moogooob | Normally Aspirated Powertrain | 1 | 03-27-2002 06:12 PM |
