Old 07-24-2003, 10:56 PM   #1
mike270
Member#: 12863
2002 2.5RS
Default Intake silicone falling into fender
I have a ganzflow and the silicone tubing that goes between the intake and the fender metal won't stay on there but for more than 2 weeks on these rough roads.
What is the best type of sealant I can put on that will hold it there but will still allow me to remove it later without much damage if I need to?
mike270 is offline   Reply With Quote
Old 07-24-2003, 11:51 PM   #2
Blindeye_03
Member#: 4418
2016 Focus ST
You mean that little piece of rubber used so you dont have a rattling sound? I used zip ties to hold mine on...
-justin
Blindeye_03 is offline   Reply With Quote
Old 07-25-2003, 12:27 AM   #3
mike270
Member#: 12863
2002 2.5RS
Yeah that piece of rubber/silicone
What did you wrap the zip tie around. I don't remember any extra holes around there.
Old 07-25-2003, 12:55 AM   #4
Blindeye_03
Member#: 4418
2016 Focus ST
there are two little holes near the BIG hole.
-justin
Old 07-25-2003, 08:08 AM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Get some clear silicone caulk and put it in the inside portion of the tubing and then put it on the opening. Leave it dry and you should be good. Other option is to use some goop instead of silicone. Both will work.
Legacy777 is offline   Reply With Quote
Old 07-25-2003, 01:06 PM   #6
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Too late for me :/ The silicone tubing fell off the fender hole as I was putting it on and vanished into that bottomless black hole that is the fender well. This was like 6 mo. ago
Is there any way I can get to it?
DrBoy01 is offline   Reply With Quote
Old 07-25-2003, 02:02 PM   #7
blackbok
Member#: 12176
2002 Geo Metro
Teal
Just tug open your fender lining. Mine fell in too. I just pulled it free (attatched by snaps I think) and fished it out. No probs
blackbok is offline   Reply With Quote
Old 07-25-2003, 02:04 PM   #8
goobie
Member#: 8273
2006 WRX Wagon
Yeah It isn't hard to retrieve. Mine fell in there too until I drilled a couple of small holes and zip tied it in place. You will just need to pull some of the black plastic away in front of the wheel well and fish around inside with your hand and grab it (if it's still in there after 6 months!)....
Chad
goobie is offline   Reply With Quote
Guy goes offroading & falls into a mine shaft Rallyroo Southern California Impreza Club Forum -- SCIC 8 04-05-2006 12:37 AM
World Cup 2006 Qualifiers - The pieces are falling into place! snvin Off-Topic 94 10-13-2005 05:14 PM
You're falling into the trap OT, and that makes me sad. WagonMonster Off-Topic 43 08-24-2005 10:04 AM
UH..Part of my intake silicon tubing fell in my fender dRu888 Newbies & FAQs 2 10-21-2003 07:13 PM
