Old 07-24-2003, 11:14 PM   #1
savka
Member#: 12737
MY02 wagon 325/300
black, no blue, no black.
Default Your thoughts on this DD log
My power mods:
EcuTek
Upipe+TB+samco hoses
Thoughts on
1. why my knok correction drops down to 5?
2.why the advance multiplier is a static value?
Or anything else you notice or would like to coment on.
thanks
sav
ps. BIG kudos to forepont for hosting these pics for me.
savka is offline   Reply With Quote
Old 07-24-2003, 11:25 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
The advance multiplier doesn't change much, and if you have not reset the ECU in a while it might have settled at its maximum value. I'm also asuming you are running a stock turbo and boost control because you can see the boost tapering down towards redline, and the knock correction is only following that trend.
cdvma is offline   Reply With Quote
Old 07-25-2003, 10:57 AM   #3
quickscooby
Member#: 39415
STI 444/452@26psi
479/492 @ 30psi GT30R .82
How the hell did you post that log? I wanna do that to get some advice on my tunning.
quickscooby is offline   Reply With Quote
Old 07-25-2003, 01:37 PM   #4
savka
Member#: 12737
MY02 wagon 325/300
friend hosted thie pictures and I linked to them.
Old 07-25-2003, 05:11 PM   #5
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: Your thoughts on this DD log
Because you dont have the octane and or conditions to run more advance then then 5 at that point.
It rarely changes. You are knocking. If you where not knocking it would be at 16 which is max. Reset the ECU. Does it start at 16? If it does I know whos ECUtek that is
Seriously though. Its doing its job. Not alot of advance but I will guess its probably hot out and you are running crapy gas?
CT
AZScoobie is offline   Reply With Quote
Old 07-25-2003, 08:23 PM   #6
mlambert
Member#: 13831
I know whos it is too
mlambert is offline   Reply With Quote
Old 07-26-2003, 11:40 AM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Don't see any pics.
jblaine is offline   Reply With Quote
Old 07-28-2003, 01:34 PM   #8
savka
Member#: 12737
MY02 wagon 325/300
Default Re: Re: Your thoughts on this DD log
CT [/b]
It is hot out, but I NEVR run anything other then 93 (94 when I stumble accross a sunoco station)
why am I geting detonation.
sav
Old 07-28-2003, 01:36 PM   #9
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: Re: Re: Your thoughts on this DD log
sav
Because its hot out and your running crapy gas
I dont see any issues.. Could be alot worse. Are you having problems? Missing power?
CT
Old 07-28-2003, 02:13 PM   #10
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
savka, I wouldn't at all be worried about it, but if you care to take the time and put forth the effort, you can determine what's causing the lower knock correction.
What have your ambient temperatures been lately?
On a cool night, if you drive around for 20 minutes and datalog at the end of the session, do you get the same results? Try datalogging at midnight outside of the city some night and see how things look.
There's really nothing "wrong" with what you're seeing in those logs. Something made them that way. If it's unacceptable to you, deal with the weather by getting a better radiator and cooling your air charge better.
Old 07-28-2003, 03:22 PM   #11
WRBLUEWAGON
Member#: 10745
2006 VW SUV
sav
Savka,
AC is right. The stock tmic get hot fast and you live in NYC so your not always getting the gas you pay for. Plus 90+ heat in our area is a killer for turbo cars. Even my car with a FMIC has a night and day feeling dorning the day and the night. Night being cooler the car just gets mean really fast.
94 from Sunoco is oxygnated (spelling) so your better off with 93 from Exxon or Shell. I always got poor milage from Sunoco 94 until I switched to Exxon 93. Same driving style and I got a good 50 more miles to the tank .
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 07-28-2003, 04:16 PM   #12
savka
Member#: 12737
MY02 wagon 325/300
Thanks everybody, I'll try dataloging on a cool night this week and then compare.
Hey Aradi how about posting a pic of your new ride
savka
Whats your thoughts on this? RexInit Factory 2.0L Turbo Powertrain 3 07-15-2006 09:09 PM
alright, tell me your thoughts on this MBasile General Community 31 06-05-2005 05:11 AM
Your thoughts on this "style" Tex-WReX Off-Topic 22 02-17-2004 05:27 PM
Message Board Statistics All times are GMT -4. The time now is 10:39 PM.
