Old 07-25-2003, 12:29 AM   #1
mista618
Member#: 8930
02 white rex
accessecu stage 2+
Default 9psi still...but why?
can somebody please help me out!?!?! i recently got a reflash so i took out my sbc-id. upon installing the reflashed ecu, i was only hitting 9psi of boost. i found out from reading some posts that i probably didn't have the stock brass resistor in a hose. i bought the part finally and installed it in the hose btw the T connector and the turbo nipple on the turbo outlet. however, i'm still seeing the exact same thing! what else could it be? i'm so freakin' confused now. thanks.....
mista618 is offline   Reply With Quote
Old 07-25-2003, 01:12 AM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Where did you get your ECU reflashed?
cdvma is offline   Reply With Quote
Old 07-25-2003, 02:23 AM   #3
mista618
Member#: 8930
02 white rex
accessecu stage 2+
cobb tuning, its the accessecu stage 2... can u help?
Old 07-25-2003, 11:40 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Did you contact them about it?
Old 07-25-2003, 01:45 PM   #5
whiterabbit
Member#: 16755
switch it over to the wastegate side not the turbo side
whiterabbit is offline   Reply With Quote
Old 07-26-2003, 03:23 PM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
Don't do this, that's not where the brass restrictor goes. It goes in the line that comes off the turbo outlet nipple, check your wastegate for correct function and look for leaks in the lines going up to your FBC. It sounds like your FBC can't bleed enough boost and is causing your WG to stick open. Some people have reported that their WG solenoid freezes with inactivity, sounds kinda strange to me, but I haven't ever disconnected my FBC for long lengths of time.
supermarkus is offline   Reply With Quote
Hawaii is paradise except for us Scooby racers! But why? is2scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 07-15-2002 07:55 AM
timing pulled but why? nicktckhoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-22-2002 02:30 PM
Want a WRX, but why so many available? speedworks Newbies & FAQs 27 05-03-2002 11:50 AM
Hacked MBC setup, but... why? GOT_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-03-2001 12:23 AM
