Old 07-25-2003, 03:12 AM   #1
PRIOR
Member#: 27524
95 Impreza L awd
2.5 swap & only 2400lbs
Default 2.5 DOHC plus 1.8 rotating assembly
ok, i have no idea if this would remotely even work... but hey, whats to lose by posting it up here....
first off, im looking at putting a 98 DOHC motor into my 95 L....
the motor is out of a forster, and i have no idea if it's one of those special "magic bullet" engines with the phase II block and DOHC.... but anyways...
i was wondering if you could pull the rotating assembly or just the rods out of an EJ18, and put them into the 2.5.... now just incase your wondering ' why the heck would he want to do that?'..... listen to this quote from mike at spd....( taken from spd's site...)
"It is interesting to note that the RA motors still share connecting rods with the N/A 1800cc motor. The quality is in the N/A motors, it is just put to different use. The 2.0, closed deck, 1995 WRX-RA short block is still the drug of choice in Japan for the "Big Power" motor."
i find this idea intresting, and since i have access to a ton of 1.8's and the 2.5 thats going into my car is gonna be on an engine stand for a while.... i was wondering if it could be done....
thanks,
andy
PRIOR is offline   Reply With Quote
Old 07-25-2003, 04:10 AM   #2
8Complex
Member#: 922
04 FXT
Red
I don't think so, but don't quote me... I have never checked personally, but I'd question the wrist pin to piston face height differences. Then again, I don't think anyone has ever checked... Mike is in a world of his own, at times.
Old 07-25-2003, 05:55 PM   #3
PRIOR
Member#: 27524
95 Impreza L awd
yeah, i was thinking that some custom pistons would be needed...
on another note, i just remebered that the good combo for high revs is a short stroke and a big bore... just like the rb26....
if the 1.8 rotating assembly gave the engine a shorter stroke... could it maybe rev better? also, something about the 1.8's being non-interference motors, and the 2.5's being interference motors....? would this change the 2.5's into non interference motors?
im not sure what non interference means, but im thinking that it means that the pistons cant come in contact with the valves.... no matter what..... i could be wrong though
could someone please clear this up for me....?
thanks,
andy
Old 07-27-2003, 01:49 AM   #4
PRIOR
Member#: 27524
95 Impreza L awd
im guessing that no one has even done this, let alone thought about it....
maybe once i get my hands on the motors, i'll tear them both down and see....im kinda reluctant to tear down the 2.5 though, as it'll be going into my car afterwards...
im def. going to tear down a 1.8 though, and then maybe i could post pics and dimensions...
i guess only time will tell.
~andy~
Old 07-27-2003, 07:29 AM   #5
ShadowIMg
Member#: 31519
2009 Legacy spec.B
2001 2.5RS Coupe
~andy~
Find a salvaged 2.5 and get an engine, shouldn't be too expensive. That way you can test all you want.
ShadowIMg is offline   Reply With Quote
Old 07-27-2003, 11:34 AM   #6
PRIOR
Member#: 27524
95 Impreza L awd
i wish i could... but money is tight (as im only 17), and im getting this 2.5 engine and wrx brakes for a great price.....
the guy is also gonna sell me a 1.8 w/ a blown headgasket for 25 bucks, so i can experiment with that one....
1998 and 1999 ECU's from 2.5. Will run 1.8 and 2.2. Streetman MWSOC Private Classifieds 3 10-31-2011 12:15 PM
WTB old 2.5 DOHC phase 1 head madmax718 Tri-State Area Private Classifieds 1 02-13-2009 05:03 PM
WTT: Silver 4dr 2.5 RS for 1.8 couple plus cash maverick326 Private Vehicle 'For Sale' Classifieds 11 04-10-2008 06:39 PM
Fitting 2.5 injectors onto 1.8? STi-Nismo Dood Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-04-2003 01:12 PM
lets make a list of all swapable parts from 2.5 into a 1.8 cindergarden Normally Aspirated Powertrain 6 08-15-2002 08:08 PM
Message Board Statistics All times are GMT -4. The time now is 03:28 PM.
