Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 07-25-2003, 10:28 AM   #1
QfactorRS
Member#: 30495
Angry low boost and low vac.
Dudes
on my way to work, car wouldn't boost above 3psi, felt like a hog.
then i noticed that i wasn't getting any positive pressure until above 4k rpm!!
Also, no fuel pressure increase when i hit boost, and vaccum numbers stay at 10 at idle. car runs fine tho.
i assumed a vaccum leak somewhere, but i haven't had time to check the engine bay, but couldn't here the usual vaccum leak sound. I'll check at lunch time.
Q
QfactorRS is offline   Reply With Quote
Old 07-25-2003, 10:37 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
check all the vacuum lines, I had one of the ones running to my intake before the turbo fall off, vacuum dropped and could'nt get more than 3psi..
rhdude is offline   Reply With Quote
Old 07-25-2003, 11:53 AM   #3
dyswtric27
Member#: 404
2000 Audi S4
endless.night
im going to guess vac line to the fpr
dyswtric27 is offline   Reply With Quote
Old 07-25-2003, 12:14 PM   #4
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Check the wiring to your coilpack. It sounds like you're running on two cylinders. You've got a J&S right? If one of the leads to the ignitor isn't solid, you'd drop a pair of cylinders.
Darshu is offline   Reply With Quote
Old 07-25-2003, 12:23 PM   #5
dyswtric27
Member#: 404
2000 Audi S4
endless.night
darshu good idea, if the car idles real rough and revs real slow when free revving then you are running on 2 cylinders. I ran on 3 cylinders for a little while until i realized that one of my injectors was not connected and it was running like crap.
Old 07-25-2003, 12:56 PM   #6
Mancini
Member#: 20726
Also check all your hose clamps. This past weekend I had one vibrate loose. Started with a loss of boost. Moved till I couldn't rev past 3000 at anything other than part throttle. Before I could even get home it blew completely and the car died. Just double check that your clamps are tight and your connectors aren't leaking.
Mancini is offline   Reply With Quote
Old 07-25-2003, 01:20 PM   #7
Darshu
Member#: 1676
98RS w/ EJ257/Dom
dyswtric27- Yeah, though, funny enough, the engine will run reasonably smoothly on 2 cylinders since the each of the two coilpacks fire opposing cylinders, the motor won't appear to run as rough on 2 opposing cyls as it will with 3 cyls.
(I was down on two cylinders at one point due to a bad connection too )
Old 07-25-2003, 02:30 PM   #8
QfactorRS
Member#: 30495
Fixed the problem at lunch.
It was a crack in the vaccum line going to my boost gauge, which is also connected to my rrfpr.
it must have crack during the swap, pinched under something maybe.
anyway, i fixed it with electrical shrink wrap for now, i'll replace the hose tonight when i get home.
thanks for all the diagnostics.
Q
low boost and vac. cruxwrx04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-28-2010 12:29 AM
Link Issues.... Low boost, and lack of RPM Crazyhippy Other Engine Management 2 12-18-2006 08:40 PM
Hesitation @ high RPM, low boost, and Fuel Cut K.Linchpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-17-2006 10:07 PM
higher altitude= low boost and no bov vent? ASpec818 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-12-2004 04:41 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 11:55 AM
