Old 07-25-2003, 03:21 PM   #1
Shizz-nida
Member#: 11491
1992 Plymouth Laser
Burned Clearcoat Black
Default Twin engine '91 Talon
A friend of mine (and former Suby owner) has been working on this project for quite some time. Its nice to see it finally running on its own power. I give you the Twin Talon!
http://kaizen.eaglecars.com/twintalon.wmv
Shizz
Shizz-nida is offline   Reply With Quote
Old 07-25-2003, 03:29 PM   #2
gongzero
Member#: 25040
Up with skirts,
down with pants!
you know, i've been thinking how cool that would be ever since i read the book A Scanner Darkly by Philip K Dick -- it's set in the near future and there's a highway scene that mentions "one of those new twin-engined Porsches".
so i'm guessing that the front engine powers the front wheels and the rear engine powers the rear? the logistics of throttle control must be a nightmare.
gongzero is offline   Reply With Quote
Old 07-25-2003, 03:31 PM   #3
Shizz-nida
Member#: 11491
1992 Plymouth Laser
Indeed... Lowtech solution has been to simply link them. We were running two gas pedals, but that proved to be a bit, um, confusing!
Shizz
Old 07-25-2003, 03:34 PM   #4
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
ROFLMAO...I love the "No thanks to Miko" part...
even though it's probably a very heavy car now, I would think that weight distribution would be fairly good.
-=C=- is offline   Reply With Quote
Old 07-25-2003, 03:44 PM   #5
gongzero
Member#: 25040
Up with skirts,
down with pants!
Shizz
very cool. i'd love to see how you've got the power going to the wheels... two transmissions? that sounds like shifting gears would be confusing too...
Old 07-25-2003, 03:54 PM   #6
Shizz-nida
Member#: 11491
1992 Plymouth Laser
Two built auto trannies. They're slaved off of one TCU. Both have Quaiffe ATB LSD's. Right now the back tranny isn't electronically connected so its in its default of third gear. Once the rear has the ability to shift gears, it should be beastly. And that's with no fine tuning, just setting the timing and letting the wastegate spring control boost (about 7psi per motor). Vinny will probably be posting soon so you can get the info straight from the Mad Scientist himself.
Shizz
Old 07-25-2003, 03:57 PM   #7
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i have a friend whos been wanting to do the same thing to his talon
jasona is offline   Reply With Quote
Old 07-25-2003, 04:31 PM   #8
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
All I got was a bunch of code when I clicked that link.
JewPac42 is offline   Reply With Quote
Old 07-25-2003, 04:50 PM   #9
Vineet Singh
Member#: 8936
Thumbs up
Haven't posted here for a while, hi everyone!
Thanks for the positive comments, the car should have been done a year ago, but we ran into engine problems after running it around for 10-20 minutes, which caused financial problems, and you know how that goes
The transmission shifter is a single stock shifting assembly, with an identical reversed stock cable (extended about 6") to a custom arm and mount on the front of the A/T. It snicks into each gear well enough, that you don't know you are shifting 2 transaxles.
Yes, the dual throttle pedals had too much play in the rear to be useful, 1/16" of play on the pedal shaft turned into almost 3/4" at the end of the arm, and the movement is only like 2" total. No need to do dual anyway, since the tranny's are linked mechanically and electrically.
Once we just welded an offset arm for the 2nd throttle, the response was within a percent or two according to the TPS sensors, and it works and sounds great.
The firewall, which was missing last year, makes a huge difference in comfort and safety. It's easily removable.
If you have any questions about the car, just post! I'm sure we will get it running better and better in the next few weeks. Right now I/we gotta take a break, had been working non-stop 12hour days for the last 5-6 weeks to get it running.
Here is what is in it,
7psi, no boost control utilized yet
No real tuning (except for timing and idle speed)
450cc injectors (please, someone send us 8 660's or 720's, thanks
18g FP turbos
Level 10 FWD A/T's with Protorque TC's
Quaife ATB's (RRE)
2.3 4g63t x2, Ross Pistons, SS valves, etc etc.
M/T cams
MAFT's from Ramchargers
Dual SMIC's for front, A/W for rear (Dejon front, Dolphies-welding rear)
Fluidyne Rad's and SS hose from Roadrace
DSS Coilovers (2 front sets)
Lexus wheels, SP9000 runflats
EVO manifolds and O2 housings (FP)
Completely sealed custom rear firewall with plexiglass top portion
3" Custom dual mandrel exhaust
Stealth RT/TT Cat (front engine only)
3000gt SL front brakes, single piston dsm front brakes in rear
2 8gal custom fuel cells
Single throttle pedal with custom ultralight aircraft cable supply house
Lots of metal shavings, welding, nuts, and tools hidden throughout
Vineet Singh is offline   Reply With Quote
Old 07-25-2003, 04:58 PM   #10
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
yeah, Car and Driver did a Twin engine CRX almost 18 years ago.
I am mattjk is offline   Reply With Quote
Old 07-25-2003, 05:00 PM   #11
JewPac42
Member#: 23260
Patr ick Willis
And Vector did a twin northstar Eldorado. Doesnt make it any less cool.
Old 07-25-2003, 05:28 PM   #12
SenorFartman
Member#: 23003
Hmmmm, front engine in drive, rear in reverse...... imagine the burnouts
SenorFartman is offline   Reply With Quote
Old 07-25-2003, 05:39 PM   #13
HalfBaked
Member#: 24759
2004 Volvo S40
Purplish-Blue-Purple
But what we all want to know...
Does it pass emissions?!
HalfBaked is offline   Reply With Quote
Old 07-25-2003, 06:39 PM   #14
Vineet Singh
Member#: 8936
Back in 1966, George Hurst built a twin engine oldsmobile 442 "Hairy Hurst Olds", and numerous tractors and dragsters with dual and even tripple engines. I wanted to own one, be streetable, and have something to do for the past 2 years Damn CORONA beers
The front engine will pass emissions with a Stealth TT cat, but not with both engines running. This is sniffer only, if it's visually inspected, probably not.
Can't do the reverse/forward, since there is only one TCU for safety and ease of use. The car can only be treated as FWD for short distances, or AWD, never RWD
We CAN adjust the rear steering rack (welded through), to give the rear wheels some tilt, and drive around @ WOT in tight circles... hmm, more interesting movie ideas
Old 07-25-2003, 06:55 PM   #15
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
wow, that was impressive. i don't even think it will be as heavy as something like that would seem to be. What does a stock talon weigh anyway?
Dolphin Overton is offline   Reply With Quote
Old 07-25-2003, 07:23 PM   #16
Vineet Singh
Member#: 8936
It's right around 3600lbs, with driver, lighter than my stock 91 Stealth RT/TT. Stock 1g's (FWD) weighed in around < 2850lbs, and 3200lbs for AWD with average sized driver and no other excess loads.
We deleted the drive shaft, the tcase, , A/C system, Radio, speakers, popup lights and mechanisims, stock fuel tank (large and pretty heavy), rear diff, ebrakes, and seats/hatch floor/spare. The new exhaust is also lighter than stock. We then added in around 600lbs of stuff.
+160 for transmission, +330 for engine/head/turbo, + ~100 for all extra fluids and containers/coolers and reinforcement.
I'm under 200lbs, and so is Tyler.
GVWR for the AWD (the chassis it's mostly based off of), is 3990lbs. We are well below that max.
Thanks for the comments!
Old 07-25-2003, 07:39 PM   #17
sperry
Member#: 8636
OBXT NA8-Miata F250
no more SVX or WRX :(
Very impressive! Make sure to post some more footage once you get the gearing and boost control worked out! That thing's a BEAST!!
sperry is online now   Reply With Quote
Old 07-25-2003, 07:44 PM   #18
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
It's been done in an old Tiburon (sp?) the pictures were way cool. Apparently it would just slowly rotate while spewing smoke.
Capt Crunch is offline   Reply With Quote
Old 07-25-2003, 10:44 PM   #19
wako29
Member#: 23412
29 Iggpoints w00t!
Hot Rod Magazine did a thing of this a little while back (note: everything following is IIRC)
it was a 442 with both motors being blown, and highly built, 455. they had a picture of it just roasting the tires when they first built it, but then they got smart and tubbed both ends with M/T tread. They showed a pic of the launch but lets just leave this ---> as to what is was like. 60 foot time was something like 1.5 seconds.
anyways, looks really good, and just keep us updated
wako29 is offline   Reply With Quote
Old 07-25-2003, 10:50 PM   #20
Handsdown
Member#: 29355
what about those twin engine suzuki hill climb monsters in GT2?
those things are the sickness.
Handsdown is offline   Reply With Quote
Old 07-25-2003, 10:53 PM   #21
wako29
Member#: 23412
29 Iggpoints w00t!
cuz those are built on a budget that says "$ is no object"
plus, IIRC, they work together kinda like the AWD Sube system. When it senses no traction in one area, it transfers power, etc.
but, they do make ungodly amount of power, plus weigh next to nothing, so yes, they are the sickness
Old 07-26-2003, 12:10 PM   #22
Jessie James
Member#: 2072
Some magazine had an article about a twin-engine Hundai at some point. Two automatic transmissions, not connected to each other, just left stock with the exception of the shifter. Full driveability.
From http://scc.primediaautomotive.com/ar...e01_0302.shtml
It also produced the most impressive burnout ever put rubber on tarmac. Michael McIntyre's twin-engine Hyundai put 627 hp to the ground in our dyno competition. It did the same thing here--in a completely different way. McIntyre's car uses two independently controlled automatic transmissions, giving him the ability to operate them in drive and reverse at the same time--which is exactly what he did. The resulting automotive tug of war was enough to send any chassis engineer into convulsions.
With the front tranny in reverse and the rear in drive, McIntyre laid into the go pedal and didn't lift until he'd made enough tire smoke to put California's Air Resources Board on high alert. The car began to slowly rotate on its axis as all four drive wheels fought each other for dynamic control. In about 10 seconds, the entire car was engulfed. When it was over, the ground was covered with smoldering piles of rubber and the most confused burnout marks ever made. He won. No one else even came close.
Enjoy.
Jessie James is offline   Reply With Quote
Old 07-26-2003, 03:46 PM   #23
pfhlipwrx
Member#: 19319
Awesome.....
pfhlipwrx is offline   Reply With Quote
Twin Engine, Twin Turbo, 626WHP, 1997 Tiburon, 10.92 1/4 mile on STREET tires alien_sporez Private Vehicle 'For Sale' Classifieds 3 05-04-2008 12:49 AM
FS: '91 Talon TSI AWD Strepto Rocky Mountains Impreza Club Forum -- RMIC 2 07-07-2003 03:17 PM
'91 Talon TSi....$1000 obo DAVE98RS Tri-State Area Forum 0 08-13-2002 05:54 PM
Look! Twin Engine Update!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ian/555 Technical Forum Archive 10 07-02-2000 05:28 AM
Twin engine! ian/555 Technical Forum Archive 12 05-18-2000 12:25 AM
