Old 07-25-2003, 03:33 PM   #1
Jademonkey
Member#: 9213
2000 RS
Red
Angry My engine blew up (sort of)
So I was driving, cruizing down the highway with a little bit of traffic, so I was going maybe 60 mph. My CEL starts flashing, and my car feels like it's only running on 3 cyl's. Hmm... maybe a plug wire got loose. That happened with my magnecor's quite a bit. So I pull over, check the wires. They look fine. I try starting the engine, and I get this very loud slapping noise on the driver side of the engine. The engine dies as soon as you let off the gas, but willl start as long as you give it a little throttle. Damn! I call AAA, and get towed to the nearest Subaru service center. They pull the plugs, and one of them is in very bad shape.
Dealer then tells me that since I'm a hair under powertrain warranty, SOA will replace my engine. Cool. Still pissed about being without a car for a week.... but it now gets interesting. Hey...look at that ganzflo. Ahh, borla header and catback. Aaah, MSD wires. You must race your car.
So they change their story. My mod's caused the engine to go bad. Now I have to pay $2,000 to have them inspect the engine, and then they'll determine if it's under warranty. So now I'm without my car for 2 more weeks. And will potentially be out $2,000 with a car that still doesn't run.
Anybody have any idea what could have caused this? I would like to think my mods didn't cause my engine to blow up...but I'm nervous about the dealership doing this inspection. I don't really trust them. I don't race my car. I religiously change the oil.
Jademonkey is offline   Reply With Quote
Old 07-25-2003, 03:48 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
When you say the plug was in "bad shape" what do you mean?
Also...it does sound like the engine was only running on 3 cylinders....but why would require more diagnostics.
Have you had any other service done lately? One thing I have learned and that I will always do in the future is to have the car towed to your house or somewhere you can get the car at least partly back to stock, expecially on major engine/trans problems.
DDMan is offline   Reply With Quote
Old 07-25-2003, 04:00 PM   #3
Jademonkey
Member#: 9213
2000 RS
Red
I didn't get to see the plug myself. They just said it was "fowled up." My guess is it was coated with oil, or coolant....or a mixture of both, maybe signs of getting smashed by a piston?
I haven't had any service done lately. I changed my oil a month ago(mobil 1 syn 5-30), and filter. The only thing I did, was a year ago, I did the 30,000 maint myself. (fuel filter, tranny fluid, diff fluid, coolant, plugs, etc). I took it in for the 02 sensor recall when I first bought it...then got the ECU reflashed under that recall...
In the future, I'll do the same. I had no idea that the engine was in such bad shape. I figured the coil pack was misfiring, or a plug wire was bad, maybe one point wasn't firing at all.
This sucks.
Old 07-26-2003, 01:21 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
For $2000 you can get another engine and then some.
Dont pay them.
Old 07-26-2003, 01:54 AM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Someone was selling a 2.5 engine with basically everything attached for 800, and he had no offers so he got desperate. I was this close to buying it. Shipping would have only been 200 from michigan.
He did a WRX swap and also had the transmission.
I think you should call Santa Cruz and tell them the story. Be totally honest and see what they can do, it could be your dealer is just a punk.
Old 07-26-2003, 08:18 AM   #6
bvondran
Member#: 15634
2001 Impreza 2.5 RS
Don't let them f*ck with you. To deny your warrany, they have to prove that the parts you installed caused you parts fail. Also, last time I checked (haven't been though business law since I passed CPA exam), "guessing" you did something (like racing) was not a valid defense to an enforceable contract. Put it to em, don't let 'em screw you.
**Unless you have had the car on the race track (not autox, but actual racetrack), cause then you might need to own up to it and admit the failure might not be Subaru's fault (street cars aren't necessarily built for the track).
Brian
bvondran is offline   Reply With Quote
Old 07-26-2003, 01:48 PM   #7
Jademonkey
Member#: 9213
2000 RS
Red
My car is a commuter... I definately don't race it. I have 58,000 miles on it. Trips to Reno, Arizona, and a 64 hour drive fest from Berkeley to Minneapolis and back, plus a regular commute from Benicia to Berkeley. There's something about racing a car that I'm making payments on, and depend so much on, that doesn't make much sense.
They already took pictures of the engine and sent it off to SOA. SOA has assigned me a case number, so I guess at this point, all I can do is wait for the verdict.
worst case scenario, I'm out $2,000 with no running car. What are my options from there? Any suggetsions at that point?
Best case scenario, they replace my engine, and I trade my car in for something that doesn't break down after 58,000 miles.
Old 07-26-2003, 07:38 PM   #8
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
Well, I don't know if this is helpful to you or not, but have you considered buying a good used motor? I mean, for less than $2k, you might just be able to go to the junkyard and pick up a low mileage 2.5 engine. Not to mention that so many people now are doing EJ20 swaps, I don't think that it would cost so much.
Well, just thought I'd throw that out for you to consider.
Which dealership did you take it to?
DoorKnob is offline   Reply With Quote
Old 07-28-2003, 09:37 AM   #9
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
at 58K miles..almost sounds as if your timing belt jumped a tooth or 2. causeing it to run incorrectly on 1 or 2cyls, if not all 4.
EJ20 swaps can be done for about 2K in parts..but then there the whole labor thing too, unless you can do it.
that really sucks tho.
Murray
Murray is offline   Reply With Quote
Old 07-28-2003, 10:10 AM   #10
Jademonkey
Member#: 9213
2000 RS
Red
I hope it's the timing belt... they can't blame that on my exhaust.
I'm pretty sure I could do the swap myself....accept the wiring...but I doubt I could take the time off work to do it.
Old 07-28-2003, 10:43 AM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
$2000 to inspect a car that is under factory warranty doesn't make any sense. You really should have towed the car to your house then removed the performance parts you had on there.
I can't stress this enough: Don't take your car to the dealer with performance parts installed that you could easily remove. Exhaust mods normally aren't that big a deal so you aren't taking a chance if you leave them installed. However when you get into ignition systems and fuel computers thats when a dealer or even a technician's eyebrows go up. If there is no beyond a doubt evidence like a broken timing belt or leaky head gaskets, better yet even if there is beyond a doubt evidence they may still deny you on grounds of your mods.
USDM EJ20 swaps seem to be around the neighborhood of $4000 in parts.
If your talking about a JDM Non OBD-II EJ20 and ECU I have seen them as cheap as $850. Good luck passing emmisions in most states though. You shouldn't have any problem passing a tail pipe test but most states are now plugging a scanner into the OBD-II port and are looking for check engine codes. This isn't a problem if you have a 95 or older but since yours is a 2001...
I'm not sure if there are piggy back or even full replacement ecus that retain OBD-II compliance and don't throw CELs when you swap a turbo motor in. Actually you may want to talk with Cobb about their Accel reflash or Vishnu about there EcuTeck reflash system.
Good luck with all of this and let us know how it turns out.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 07-28-2003, 11:21 AM   #12
Jademonkey
Member#: 9213
2000 RS
Red
At least I know I have some options at this point. I had no idea the damage was as bad as it was. I pulled 3 of the 4 plugs, and when the tow truck got there, I said to just tow it to nearest service center. I figured it was a bad coil pack or a wire...had no idea the engine was in such bad shape. I'm going to call the dealership in about an hour, and get an update.
edit: just called dealership, and they haven't done anything to it yet...
Old 07-28-2003, 03:00 PM   #13
Jademonkey
Member#: 9213
2000 RS
Red
Damn, I knew I should have taken it to the dealer I bought it from. I just spoke with the warranty advisor. When I explained to her what happened, she said "that's odd... i don't think your after market parts would have caused that to happen."
Old 07-28-2003, 04:09 PM   #14
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
If I were in this situation I'd call the dealer that has not touched it and tell them not to, then have the car picked up and taken to the dealer you trust. It sounds like they are already playing games with you and you'll likely save more money by dealing with other people than your going to pay to have it towed again.
nunyo is offline   Reply With Quote
Old 07-30-2003, 11:22 AM   #15
Jademonkey
Member#: 9213
2000 RS
Red
Default Update
I just spoke with the Service Manager, since nobody else at the dealership is returning my calls. The engine is apart, and they found the problem. One of the pistons hit a valve. They say that i was revving my engine at high RPM's causing a valve to float, then a piston slammed into it. They're going to take pictures and send it to the local SOA rep. Basically they're accusing me of racing it. The manager said "This only happens when you're revving it at high RPM's."
Could somebody give me some help here?
Old 07-30-2003, 11:48 AM   #16
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Do any of the aftermarket ignition bits you installed give you the ability to raise the rev limiter?
Old 07-30-2003, 12:52 PM   #17
Jademonkey
Member#: 9213
2000 RS
Red
The only thing on my ignition are MSD wires I made (scoobymods.com) .
Old 07-30-2003, 01:35 PM   #18
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Your argument to SOA needs to be that you did nothing to alter the revving boundaries set by the factory engine control unit.
Sorry for some reason I only read MSD and thought full ignition control system.
The dealer really has no excuse for not warrantying your car. I have a feeling SOA will tell them to warranty repair your car. If they give you trouble find a lawyer that will read the fine print of your warranty contract and right a letter to SOA when he has found that SOA has not proven that you did anything to cause the engine failure. The lawyer would cost you less then $2000 trust me.
If all else fails JDM EJ20 turbo motors are going for $850 on ebay.
brad
Old 07-30-2003, 01:58 PM   #19
Jademonkey
Member#: 9213
2000 RS
Red
Thanks Brad, I appreciate your input. I just spoke with my dad who is a fleet formean for PG&E (california electrical utility company) and he said the same.
I also want them to get a freeze frame data log of the engine conditions at time of CEL. They'll see that the engine was driving at 70 mph, @ 3000 rpm's.
Old 07-30-2003, 03:27 PM   #20
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
When was the last time you changed your timing belt? If you have never done it, then 58,000 miles is well beyond it's normal service life.
ChrisW is offline   Reply With Quote
Old 07-30-2003, 04:10 PM   #21
Jademonkey
Member#: 9213
2000 RS
Red
Timing Belt? You sure it's well over? According to the maintanence schedule, it should get changed out until slightly over 100,000 miles....
Old 07-30-2003, 04:51 PM   #22
foolio
Member#: 9351
2006 trailblazer SS
black
Timing belt services are not needed until over 100k.
I would call the dealer and ask which rep from SOA they are dealing with. Tell them the situation and maybe you will get someone who cares on the other side of the phone. Dealers really dont care.(some do) I would talk to the person who is handling your case at SOA.
foolio is offline   Reply With Quote
Old 07-30-2003, 05:27 PM   #23
Jademonkey
Member#: 9213
2000 RS
Red
I asked if I could contact the rep handling the case. The Service Dept Manager told me No, and that they would contact me after SOA rep reviewed the case.
Old 07-30-2003, 09:46 PM   #24
ldivinag
Member#: 13533
04 sti
black???
this sounds a little "fishy"...
i'd called SOA directly if this is standard practice.
btw, which dealer is this?
ldivinag is offline   Reply With Quote
Old 07-30-2003, 10:50 PM   #25
Jademonkey
Member#: 9213
2000 RS
Red
Dealer is Green Valley Ford.
My engine blew what would you do? Initialdaddict General Community 41 08-19-2009 11:54 PM
Engine blew up in my 2003 Subaru Baja NA, please advise bajaSeven Normally Aspirated Powertrain 14 10-06-2008 03:24 PM
BMW 335 engine blew up twlai Non-Subaru News & Rumors 39 09-11-2006 11:53 PM
friend bought an audi, engine blew up, she got screwed, need new engine.. (help) Keith Off-Topic 75 02-02-2005 07:43 PM
