Old 07-25-2003, 05:57 PM   #1
Eaglesfan2422
Member#: 26445
Default pulley problem I think, stock pulley
I removed my underdriven pulley a few days ago and put the stock one back on. There's a weird loud noise and it sounds like it's coming from the A/C pulley. At first I thought it was an uppipe leak but I don't hear anything at the uppipe manifold flange or right near the turbo, it is definately coming from between the alternator and the AC compressor. I can also feel a bit of warm air coming up from that area, is that normal? but no air between the power steering and alternator ones.
Also I checked the crank pulley bolt and it looks like it's loose, but the pulley doesn't wobble around, regardless I will torque the bolt down again. So I think the noise is either the loose crank pulley bolt, or maybe the belts are too tight? But they were just as tight with my old pulley. There's also that warm air between the alternator and A/C pulleys.
Eaglesfan2422 is offline   Reply With Quote
Old 07-25-2003, 07:35 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
The specs for the belt tension are in the owners manual if you want to check. sorry I can't be of much help. good luck.
PaulRex is offline   Reply With Quote
Old 07-25-2003, 08:59 PM   #3
Eaglesfan2422
Member#: 26445
I tightened the crank pulley bolt down, it was already fairly tight. That must have been the majority of the problem because it got much quieter. U have to listen for the noise now, before it was pretty obvious. I searched and found that someone used the stuff called belt dressing, I'll try that as well.
Old 07-25-2003, 11:48 PM   #4
desiwrx02
Member#: 20168
02 wrx
black and blue all over
96 lb-ft on the crank pulley...
desiwrx02 is offline   Reply With Quote
WTT: Gofastbits Lightened crank pulley for Stock Pulley Jus Blaze Tri-State Area Private Classifieds 1 10-11-2008 09:06 AM
FS: Stock Flywheel, Stock Shift Linkage, Stock Springs, Stock Hood, Stock Pulley, Sto Asuby Drivetrain 6 09-25-2006 10:23 PM
Underdrive pulley problems Overtime Normally Aspirated Powertrain 4 03-01-2001 07:56 PM
UD pulley or light weight stock size pulley? Derres Catalano Normally Aspirated Powertrain 1 02-14-2001 12:56 AM
Part #'s for stock pulley belts...removing UR pulley SFsube Technical Forum Archive 4 08-26-2000 09:46 PM
