Old 07-25-2003, 08:28 PM   #1
viodea
Member#: 7497
WR Blue
Default Help: Hood doesn't close
I just installed my Morettes. After the installation, I closed the hood but it didn't close. Seems like something is blocked. I looked in there and don't really know what's wrong.
Any idea what's going on?
Does anyone have a pic of their hood lock?
thanks
viodea is offline   Reply With Quote
Old 07-25-2003, 11:08 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This is normal after installing Morettes because the top part of the light assemblies sits above the radiator support where the hood seal makes contact. The "solution" is to hold the hood higher before releasing it, then it will close. Over time it will get easier to close as the seal compresses to fit the Morettes.
Old 07-26-2003, 04:05 AM   #3
viodea
Member#: 7497
WR Blue
are you sure. I tried to close it pretty hard and it didn't close.
Did you have the same problem?
I also tried to let it set and push hard downward and still didn't work.
I'll try to hold it higher before releasing it tomorrow and see if it works.
Just to be on the save side, how high did you hold yours?
thanks
Old 07-26-2003, 08:04 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Don't try to close the hood by pushing on it. Not a good idea with an aluminum hood as you can bend or dent it.
Hold it up a few feet and let it drop, it should close.
Also try loosening the mounting bolts for the lights and push them as far down as possible while retightening, that may help.
Old 07-26-2003, 08:36 AM   #5
Karl
Member#: 13110
This may be obvious, but are the lights properly seated? I know when I installed the Subaru projector lights, the bottom of the light can be hard to seat properly.
Karl is offline   Reply With Quote
Old 07-26-2003, 10:12 AM   #6
viodea
Member#: 7497
WR Blue
mulder: you are right. I guess a 3 feet drop is not enough. I lift it up high and drop it around 4 feet and it just locked.
thanks you all.
I have a sunroof that only opens...and doesn't close... speed_ga Interior & Exterior Modification 9 09-19-2008 11:41 AM
Hood Never Closes WXCESS Warranty Issues & SOA Problems 6 01-28-2005 02:04 PM
freshly painted hood doesn't match too well Proxy WRX Interior & Exterior Modification 12 09-22-2004 10:49 AM
help: sub doesn't make any bass kitbar Car Audio, Video & Security 8 07-07-2004 03:17 PM
my hood won't close ychan Service & Maintenance 11 02-18-2003 08:47 AM
