Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-25-2003, 09:38 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default So What Does This Do? (radiator ques)
I just got my PWR radiator today and it looks great. There were a couple bent fins that I corrected, but there are also some tabs at the bottom that are bent. I'm sure I can bend them straight, but I don't think I'm going to need them. As far as I can tell, they are used to mount the 'radiator under cover'. But what does it actually do? I would imagine Subaru thought it was useful in some way, but I fail to see it. This radiator is going into my GFA conversion, so I don't have this cover to analyze.
You can see this cover just below the radiator in this picture marked as (29):
-Jon
Old 07-25-2003, 09:43 PM   #2
mlambert
Member#: 13831
From the picture I say lose it, but my suggestion might change if I saw it in person.
mlambert is offline   Reply With Quote
Old 07-26-2003, 12:20 AM   #3
Austin
Member#: 7089
That piece encourages cooling air to travel through the core fins, instead of around the bottom of the radiator core.
Austin is offline   Reply With Quote
Old 07-26-2003, 12:54 AM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Austin, that is what I would figure, but the placement doesn't really make sense. To me, the air above the radiator support is already going to go through the rad and a barrier below and behind the radiator wouldn't have that great of an effect. Of course, I don't have one to look at so I can't be sure.
-Jon
Old 07-26-2003, 09:42 AM   #5
Austin
Member#: 7089
It's the same idea as rubber ducting for a TMIC, the same reason you have foam between the top of the radiator and the support that goes in front of it. The same reason there is such a tight fan shroud on the two radiator fans.
Air will always take the path of least resistance (like anything), and flowing through a heat exchanger core is not low resistance compared to flowing around a heat exchanger core.
So what does this mean?! ADirtyLegacy Legacy Forum 7 04-10-2007 12:08 PM
Dumbass landlord/roommate: toilet was leaking, so what does he do? 24 Off-Topic 27 08-08-2005 08:49 PM
So what does everyone do w/ the pre-drilled holes & mount w/ no front plate? Ohannon7 Interior & Exterior Modification 8 04-04-2005 05:14 PM
I'm confused, so what does XP do when... bobturismo Off-Topic 2 12-07-2004 10:05 AM
What does this do? Keiho Normally Aspirated Powertrain 6 10-30-2000 10:51 PM
