Old 06-13-2001, 08:39 PM   #1
amp5
Member#: 7331
Post Big WRX Turbo problem, Help?
My 1300mi new WRX is having trouble accelerating. The turbo seems to have become totally non-functional and the car feels like a 110hp Kia. WHen the gas is pushed all the way down I don't hear the turbo nor is there any turbo-charged acceleration. The check engine light flashed last night but it hasn't come on since.
Anyone had a problem like this? I'm concerned I may have gotten a Lemon WRX! The dealer (surprise!) denied any knowledge of problems with the WRXs. Is he right? Thanks everyone.
amp5 is offline   Reply With Quote
Old 06-13-2001, 08:54 PM   #2
littleblue
Member#: 6171
WR Blue
Post
just about 4000mi on mine w/ no problems. Take the car to the dealer is all I can say.
littleblue is offline   Reply With Quote
Old 06-13-2001, 09:00 PM   #3
blaznasn
Member#: 6750
Post
did u take it to far over the limit when u were driving?....did u follow the rules about breaking in the turbo??....otherwise...look on the website or the manual for warrantees...there should be some....or ask your dealer
blaznasn is offline   Reply With Quote
Old 06-13-2001, 09:03 PM   #4
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Post
Is your WRX manual or automatic? If it is manual and you are in the wrong gear the car will feel like a kia. Any weird sounds that came from the turbo when you got a CEL? Did the dealer pull any codes from the ecu?
illmatic is offline   Reply With Quote
Old 06-13-2001, 09:08 PM   #5
amp5
Member#: 7331
Post
Hey thanks guys, the car is going to the dealer on Monday and it's a manual. I babied this car through the break in period so I've only really been able to push it for 300 miles. I was driving normally when it happened. I'm essentially wondering if anyone else has had this problem because I know the dealer will fix it. It'd be comforting if I'm alone and other WRX's aren't having this problem...
Old 06-13-2001, 09:14 PM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Post
Hmmmmm...
What have you done to it?
What is the transmission?
Do you have access to someone who has an OBD-II scanner
Do you hear ANY sort of turbo spool at all?
Have you looked for obvious stuff under the hood in the intake system? (hoses that have fallen off, etc?)
Stand under the hood and rev the motor and listen for gasping sounds not coming from the intake opening (by the radiator) could signify a intake leak... conversely listen for any sort of leaks near the intercooler blow off valve for things that would prevent your from boosting.
Does the car drive fine... just slow?
Or is it bogging and sputtering?
Do you smell any thing rotten?
When you say the gas all the way down.. are you refering to sitting in neutral and doing it? Or under load on the road at WOT at 6000 RPM?
Just a few things that will help the troubleshoot...
Jorge (RiftsWRX) www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
02 Wrx Turbo Problem Need Help Asap vroomvrroom7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-16-2006 03:50 PM
02 WRX turbo problem need help please vroomvrroom7 Normally Aspirated Powertrain 3 02-16-2006 03:31 PM
04 wrx turbo problems *help* wojtek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-27-2005 11:40 AM
Just installed FMIC and i have a turbo problem HELP!? CarbonFiberWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-24-2003 08:59 AM
Legacy Turbo Problems- Help Please!!! thrillwill Legacy Forum 6 05-26-2002 02:17 PM
