Old 07-26-2003, 07:49 AM   #1
Zigenroller
Member#: 34794
2004 STI
White/Gold
Default Vortech FMU
I have a 10 to 1 plate in my Vortech FMU and run way rich i want to know if the 8 to 1 plate is thicker or thinner.
Zigenroller is offline   Reply With Quote
Old 07-26-2003, 12:16 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
You should put the 4 to 1 plate in it. THat's what I have found works best
Drac9 is offline   Reply With Quote
Old 07-27-2003, 12:05 AM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Of course, choosing the correct plate depends on how much boost you are running. When I had my Vortech FMU installed I could never figure out which plate was which.
Sorry I don't have any information for you.
Graham
Graham is offline   Reply With Quote
Old 07-27-2003, 04:07 AM   #4
TMR Impreza
Member#: 168
2011 M3 and 328i
white and black
Definately 3-1 or 4-1. After that the car runs extremely rich and forces the injectors static.
www.tmrmzine.com
TMR Impreza is offline   Reply With Quote
Old 07-27-2003, 04:07 PM   #5
smacksube
Member#: 4067
01 2.5 rs
i beive the smaller the plate the less fuel pressure it puts out....waity...are you rtalking abouit the rrfpr or something else...whatever.....
smacksube is offline   Reply With Quote
Old 07-28-2003, 02:01 AM   #6
Drac9
Member#: 9861
3 to 1 or 4 to 1 means that for each lb of boost it will add 3 or 4 lbs of fuel respectively. So, with a 4 to 1 plate running 5 psi at full boost it will add 20psi of fuel pressure on top of the pressure provided by the stock fuel pump.
Vortech FMU Calibration Suggestions SCOOBER Engine Management & Tuning 0 05-14-2003 06:08 PM
Vortech FMU Question... SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 0 05-05-2003 03:03 PM
Do I need to put the Vortech FMU at the end of the vacuum line? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-20-2001 04:33 PM
Will this MSD adjustable FPR work along with the Vortech FMU? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-15-2001 11:48 AM
Puzzled by Vortech FMU Full Recal Kit the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 16 10-15-2001 03:15 AM
