07-26-2003, 11:55 AM | #1 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
Where did you mount your gauges and why?
I already have the column mounted boost gauge. I'm looking to get EGT, oil temp and oil pressure gauges. But I can't figure out whether to put them in the spot where the clock is, or whether to replace the stereo with a single DIN head unit and the put the gauges there.
I've seen the latter and it looked very very clean (Omori gauges). But at the same time I'm not sure I'm willing to give up the 6-CD changer. But if I could find a head unit that was red/green it would probaly look rather awesome and maintain the stealth I'd like. A-pillar is out - I don't like the way it looks and I don't want to attract the attention. So - arguments for/against the DIN spot vs the clock spot would be very much appreciated Whether or not you can see them, whether the 5-0 cares, whether you really miss the clock... yada yada... Thanks! -bd
07-26-2003, 04:12 PM | #2 |
Member#: 15106
imo, you need to orient the guages strategicly so that you can see related metering in one view. basically i think the boost and tach needs to be close, even better boost tach and a/f wideband if you have it.
imo, a-pillar is probably one of the best location next to the steering column even though you may not like it. clock area is imo too far right and out of view for fast activity guages unless they are fairly large. dash and center console are probably good for slower lower activity meters such as volt, intake temp, nos pressure, etc. so i think you're limiting yourself by not using the a-pillar. its not there just for show, actually for some. |
07-26-2003, 04:38 PM | #3 | |
Member#: 17301
I'm not saying people who put them on the A-pillar are showing off - just that I don't want them there -bd |
07-27-2003, 09:57 PM | #4 |
Member#: 18642
Vehicle:2005 Impreza WRX STi |
I'd put them in the clock location using the Subaru pod. This works very well. I have my Oil temp. EGT and Oil Pressure gauges there, all Autometer Phantom.
No matter where you put the gauges, you won't be able to look at them during an autocross, that's for sure. I can't even look at the tachometer during autocross. However, on the street or even at the dragstrip it's very easy to take a glance over at the readings. This location is convenient and IMHO looks much less " tacked on" than the a pillar location. I've yet to see a A-pillar set up that looks well integrated into the rest of the car. Gonz. |
07-28-2003, 03:12 AM | #5 | |
Member#: 26445
I have my boost and EGT on the steering column, oil temp in the cupholder near the e-brake. |
08-04-2003, 06:17 PM | #6 |
Member#: 18823
Vehicle:2011 with 4 wheels monochrome? |
Hey BD,
I have the Autometer 2 gauge bezel pod (similar to what the civics have on the gauge bezel pod) I am getting the HKS CAMP, which I have mentioned before.. It has all you need for all the guages displayed on an LCD monitor (which I will be recieving pretty soon).. it will take over the main headunit.. just look up "WRX CUSTOM MONITOR LCD" on ebay, and you'll see what I bought. I kept all gauges near all the instrument clusters so I can keep my driving vision clear from obstructions.. best thing to get is a HUD (heads up display) if you can. But a monitor/LCD will do. Keefe |
08-05-2003, 04:13 PM | #7 |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
I believe the best location for the boost gauge is near the tach. I use it constantly when trying to control my boost level: when the engine is still cold (keeping RPM's down as well), gas mileage, etc. I look at my Oil Press. gauge mostly in the morning. Since I don't currently have an Oil Temp gauge, I use the Oil Press to figure out when my engine is fully warmed up (pressure will settle around 30 psi @ idle and around 80 psi when cruising). After that, I just look at it occasionally. My third gauge is a Volt Meter which is probably the least important of the three as far as visual priority. All of my gauges are mounted in the center pod (52mm Omori's). I will eventually move my boost gauge to the steering column and either replace the empty spot with a clock or an Oil Temp gauge. The main reason I used the stock gauge housing/location is for subtlety and convenience.
- Kean |
08-05-2003, 04:23 PM | #8 |
Member#: 10757
Vehicle:2013 BRZ Limited 6MT DGM |
I have the stock boost gauge on the steering column so that when I look at the tach, I can see the boost relatively quickly. I am also running a Defi pod with 60mm Greddy warning gauges (boost, EGT, and oil pressure). I wanted the other boost gauge so that I can glance at it while driving and with the warning features on the gauges, I can see the lights out of the corner of my eye while driving. I also bought a 60mm corner pod from Subie Gal. I may add a fuel pressure gauge in the future and plan to stick it there.
Calvin |
08-05-2003, 05:25 PM | #9 |
Member#: 24369
Vehicle:2002 WRX White |
I just purchased the autometer 2 pod cluster bezel that goes inside the instrument panel. Any recomendations on what two gauges to put in? I was planing on boost gauge and EGT, the most I plan to do other than the exhaust work, is a MBC. Thanks!
08-05-2003, 06:22 PM | #10 |
Member#: 19647
Vehicle:2002 WRX Sedan 12.697 @ 108.95 |
I have mine where the clock was, angled towards me. On the pillar messes up my peripheral vision, so that's why I avoided it.
Here's a bad pic before they were permanently mounted: |
08-05-2003, 11:59 PM | #11 |
Member#: 17301
Hey... thanks everyone for the advice. I think I am just going to ditch the clock and get the stock gauge pod. The 1-DIN stereo, 1-DIN gauges looks awesome and oh so stealthy but when it comes down to it I don't want to go back to a single CD player (not to mention I couldn't find one that matched the green/yellow that would be everywhere else). So I will just have to find some clock to jam next to the cupholder.
Keefe - I want to see that setup once it's done - it sounds awesome! -bd |
08-06-2003, 02:35 PM | #12 |
Member#: 21641
International
Vehicle:4EAT [email protected] Now a 6MT! beyatch! |
why do you have to ditch the clock? jason |
Where did you mount your tweets?? | Stevins | Car Audio, Video & Security | 11 | 04-08-2003 04:36 PM |
Where did you mount your HID ballasts? | buymeasti | Electrical & Lighting | 11 | 03-15-2003 10:24 PM |
where did you mount your scramble boost switch? | wrxtuner02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-12-2002 09:39 PM |
Poll: Where did YOU mount your crossovers? | stimpy | Car Audio, Video & Security | 8 | 10-23-2000 02:27 PM |
S-AFC Where did you mount yours | tmaler13 | Technical Forum Archive | 1 | 09-02-2000 10:54 AM |
