Old 07-26-2003, 02:49 PM   #1
schwarzenegger
Member#: 37014
2003 WRX spec R1
Yellow
Unhappy Damn it, I think I'm running too lean...
I got a P0546 error, also known as "Exhaust gas temperature sensor circuit high input". Looks like I'm obviously running lean or is it? Strangely enough tho, this error never veered its head until yesterday under normal load... and I haven't changed anything, no mods, no nothing. It just all of sudden appeared...??? So i'm wondering if the sensor burnt up or something...
Does anybody have experience with this or have some insight on this problem? Please help! maybe the list below might help...
Current engine mods and setup:
HKS down and up both have no cats. (CEL but fixed with resistor)
GReddy EVO cat-back. (I got no cat so is it still a cat-back? haha)
GReddy MBC set at 1.2 BAR or 17 psi. (been running it, no prob)
Foam drop-in filter. (no CEL)
schwarzenegger is offline   Reply With Quote
Old 07-26-2003, 03:13 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Isn't that the code the stock EGT sensor would throw with high EGTs.. is your resistor fix you said you have for the upipe sensor, or the 02 sensor in the rear exhuast for the P0420 code?
Do you still have the stock EGT sensor in the HKS upipe? Or is the resistor fix there? If you have stock egt sensor in there, and a MBC I'm guessing that high EGTs at part throttle is triggering the code..
PaulRex is offline   Reply With Quote
Old 07-26-2003, 03:22 PM   #3
schwarzenegger
Member#: 37014
2003 WRX spec R1
Yellow
Question
I'm trying to find out if the second O2 sensor on the downpipe is one, also a EGT sensor and two, if not then can it also trigger the P0546 error??? As far as I know, the only error that the second O2 sensor sets off is the P0420 error, also known as "Catalyst system efficiency below threshold" usually due to a blown cat or a no cat.
Old 07-26-2003, 08:21 PM   #4
schwarzenegger
Member#: 37014
2003 WRX spec R1
Yellow
Thumbs up This just in...
Just found out that the second O2 sensor will NOT set off the P0546 error. The part 22629AA012, otherwise known as "Sensor assem. ex. Temp" is solely responsible for this error. Also found out that once detection's been made, the sensor is most likely cooked thus requiring a new assembly. Luckly the new part isn't too expensive and easy to install but my problem still persists: Engine running too lean; EGT above threshold...
Does anyone know what idle and full load fuel pressure should I be running if I'm runnig 17~17.5 psi? I have intake, downpipe, uppipe and cat-back exhaust.
p.s. please help a.s.a.p. I am running lean, quite lean... (sensor burnt off)
p.s.II what is the safe range of EGT on WRXs?
Old 07-27-2003, 12:45 AM   #5
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Turn down da boost.
Old 07-27-2003, 05:48 PM   #6
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Originally posted by Brahmzy
Turn down da boost.
I second that, especially without engine mgm't to tune the fuel map etc.
Old 08-01-2003, 02:07 PM   #7
jcnel_wrx2k3
Member#: 38268
2003 WRX
WR Blue
Default its time
Its probably time to up the fuel pump, and go for some larger injectors, with a computer tune. That way, you can really enjoy the extra boost.
Later,
jcnel.
jcnel_wrx2k3 is offline   Reply With Quote
Old 08-01-2003, 08:00 PM   #8
WRXzard
Member#: 14855
You will norrmally get that code when you run 5 th gear 80 mph
for more that 5 to 10 seconds. The ETG probe goes flat line. That is what throws the code.
If you stay out of the 5 th gear 80 (changing speed ) for more that 5/ 10 second you will avoid the code. It will clear after 5 runs.
The main concern is that the probe can get toasted and flake off into the turbo. The fix is to move it to the down pipe.
I have ran for 60,000 and I'm still ok in reguards to the EGT.
Me being Mr. Dumass I floated my valves.
I have to put miles on my STI now
WRxzard
WRXzard is offline   Reply With Quote
Old 08-01-2003, 08:14 PM   #9
03WRXMA
Member#: 35081
2012 WRX
How? Care to elaborate?
03WRXMA is offline   Reply With Quote
Old 08-02-2003, 12:03 AM   #10
TXBlueBeast
Member#: 24494
2008 Prius
I just checked and I am getting this same code. All I have is Vishnu Up-pipe, Stromung Downpipe (w/high flow cat), Stromung 3rd cat eliminator pipe, and Cobb Catback. The CEL does go off after a while but just comes back on shortly.
*edit- I also have the "resistor CEL fix"
TXBlueBeast is offline   Reply With Quote
Old 08-03-2003, 01:15 PM   #11
tundra
Member#: 9290
02 Built 2.5L wrx
The P0546 code usually means that your up-pipe O2 sensor is ready to die. If it dies your car will only run in limp mode (not fun).
This has nothing to do with high egt.... it actually means the sensor is seeing a lower egt than it is supposed to. I would pull the plug on the sensor and place a 2.2kohm resistor in it's place. Remove the probe from the uppipe and replace it with an M12x1.25 bolt.
There's been a ton of posts on this very thing. A simple search will lead to you hundreds of similar posts.
Good luck.
Edit: As a side note though, you really should turn down that boost. 17 psi is definately on the borderline of pushing the stock turbo out of its efficiency range. You'd be much safer running 15-15.5 psi, unless you are looking for an excuse to blow your engine up....
tundra is offline   Reply With Quote
Old 08-03-2003, 06:01 PM   #12
0260B4U
Member#: 33249
2003 WRX
white
17 is a very bad thing on stock sytem/turbo with no management.
0260B4U is offline   Reply With Quote
How do I know if I'm running too lean or too rich? Something Cool Here Newbies & FAQs 18 04-20-2010 10:55 PM
How to tell if you're running too lean/lean? 05ImprezaRS Newbies & FAQs 8 01-31-2007 01:34 AM
Is my NA car running too lean ? G.Subramaniam Normally Aspirated Powertrain 7 02-11-2005 07:36 AM
running too lean??? lubu444 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-25-2003 06:50 PM
Running Too Lean??? Stang2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-06-2003 12:45 AM
