#1 |
Member#: 12863
Vehicle:2002 2.5RS |
I am going to add another ground wire from strut bolt to the engine but I need to know what the torque specs are for either the manifold bolt on the drivers side and the torque for the strut bolts.
#2 |
Member#: 12863
bump
#3 |
Member#: 33901
Vehicle:04 04 STI No AWD, Not interested |
#4 |
Member#: 32846
Vehicle:1998 Impreza L-SOLD Arcadia Green |
Not sure about the strut torque, but may have a better solution if you haven't already did it. I ran a 27" piece of 6 gauge from the battery down near to where the original ground is near the starter. It is right underneath the vacuum hose running from the brake booster to the intake manifold. It was an un-used 13 mm fine threaded hole that worked perfectly. I used some aluminum tape to protect it from heat for the first 6 inches to protect it from heat.
-Charles- |
#5 |
Member#: 4418
South East
Vehicle:2008 S2000 Black |
If you are referring to the strut top bolts, they are torqued at 12ft-lbs and +or- 4ftlbs.
-justin |
| Thread Tools | |
| Display Modes | |
| How much torque on the case bolts??? w/arp case bolt kit | hectowrx | Built Motor Discussion | 6 | 10-08-2008 08:55 PM |
| required torque for sti bolt on bearing bolts? | homer09 | Brakes, Steering & Suspension | 3 | 03-21-2008 09:28 PM |
| questions about correct torque on oil drain bolt and tranny fluid bolt... | IMPRZME | Newbies & FAQs | 7 | 11-14-2004 11:00 PM |
| Help: Need torque numbers for the strut bolts, brake bolts and lugnuts for wheels | Sordid Philosopher | Brakes, Steering & Suspension | 3 | 11-22-2002 09:27 AM |
| uppipe: 26-30 lbs of torque on all bolts? | makanouchi | Factory 2.0L Turbo Powertrain | 1 | 09-05-2002 10:32 PM |
