07-26-2003, 08:10 PM | #1 |
Member#: 38402
Vehicle:2004 WRX~vf34 SOLD EVO MR |
Which and where to buy HID?
Im new at this and wonder which hid is the best. Which one do i buy???
Help
07-28-2003, 11:34 AM | #2 |
Member#: 8924
Vehicle:2002 Impreza WRX WR Blue |
I need some advise on this too please.
Thanks. |
07-28-2003, 12:14 PM | #3 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
I have a Philips 4300K kit and one of the best purchases so far for me. I'm running them through projectors though instead of the stock reflectors. Run a search for "Philips HID kit" and you'll pull up info on where to buy and some more in-depth info.
07-28-2003, 05:48 PM | #4 |
Member#: 16071
Vehicle:2005 G35 Sedan Twilight Blue |
I bought a set of Catz H1 HID from www.suvlights.com.
But due to some 'ban' regulation they aren't listed. Check another thread in this forum. |
07-28-2003, 09:24 PM | #5 |
Member#: 38402
are the philip 4300k for low beam? how about these from ebay? good?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2424896766 What you mean by "ban"??? is it illegal? |
07-28-2003, 09:34 PM | #6 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Those are H4s, they won't fit your '04.
07-28-2003, 10:28 PM | #7 |
Member#: 38402
So which one will fit?????? I HAVE NO CLUE
HELP |
07-28-2003, 10:41 PM | #8 |
Trust no one
It depends on the bulb that the '04 uses for low beams. I don't know what it is offhand but someone may post it, or you can just look in your owners manual. The specifications for all the bulbs in the car will be in there. For an aftermarket HID kit to work it would have to be made to replace that particular type of bulb, i.e. H1, 9005 etc.
I have not seen any '04's yet with HID retrofits but if experience with '02-'03's is any guide here adding HIDs to these lights may not produce ideal results since they are reflectors. The light will be bright but not well controlled and will probably cause glare to oncoming traffic. It is true that the '04 STi has factory HIDs in similar light housings, but the design of the reflectors in the STi is most probably different to accomodate the high output of the HIDs. If you have the $$ the best thing to do would be to buy a set of US spec STi HID lights. They will bolt right in, in place of your existing lights. Some minor wiring work might be required to connect the ballasts, but you will then have the best light output possible for your car. Alternatively, you may want to wait a bit to see if the aftermarket comes out with projector lights to fit the '04's. These will provide better light distribution than the OE reflectors and will also be better candidates for HID conversion. |
07-29-2003, 12:17 AM | #9 |
Member#: 38402
The manual say their h1 so i look for h1?
Why would someone buy the sti headlght just for the hid...... it cost 1000.00 for a set of those. |
07-29-2003, 01:39 AM | #10 | |
Member#: 16157
South East
so i have an eBay fmic, how do i get the bov to mount? and where to buy couplers? | legacy2003 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 01-04-2007 11:47 AM |
First time skiing. What gear to buy and where to buy it? | plunk10 | Mid Atlantic Impreza Club -- MAIC | 14 | 12-19-2003 09:32 PM |
Need inexpensive rims and winter tires for STI, what and where to buy ? | jaytone | STi Forum Archive | 17 | 09-06-2003 06:45 PM |
turbo timers- which one and where to buy? | plas | Newbies & FAQs | 4 | 04-23-2002 10:24 PM |
Which TURBO TIMER and where to buy in Houston? | metoo | Texas Impreza Club Forum -- TXIC | 7 | 03-20-2001 10:18 AM |
