Old 07-26-2003, 09:20 PM   #1
jbogli
Member#: 26006
2002 Impreza WRX
Default vf-22 map for utec
Hello i am looking for a basemap to look at with a vf-22. I am currently running vf-22, sti injectors, walbro fuel pump, utec, txs stealthback, perrin uppipe and aem cai. Does anyone have a map that i can take a look at. It is basically stg 4 but with a vf-22. Should i just start with the stg 4 basemap and work from there?
Thanks
justin
jbogli is offline   Reply With Quote
Old 07-27-2003, 04:14 AM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Yeah start with the stg.4 why not.. Just remember the differences between the VF30 and the VF22 and tune appropriatly. Study the map, see why it is like the way it is do some tuning and datalogging, make adjustments to one map at a time in small increments.
The fuel map and the ignition map are largely influenced by when the turbo spools up and how much boost it runs across the rpm range, so if the VF22 is spooling up alittle slower than the VF30 then maybe you can lean it out at certain rpms where the map might be adding in fuel for the Vf30 that already came on boost 500rpms earlier etc. etc.
If you think you are getting in over your head with the fuel map when roadtuning, take it to a dyno when you have time and use a wideband there is my advice. I see you live in CT, you can go to Pruven then.
PaulRex is offline   Reply With Quote
Old 07-27-2003, 09:11 AM   #3
jbogli
Member#: 26006
2002 Impreza WRX
Default Thanks
Thanks for the reply. I was planning on Dyno tuning i just wanted to get the car up and running so it is driveable.
Thanks
Justin
vf-22 map needed globalrex UTEC 19 12-18-2008 07:49 PM
vf 22 map needed please :) TevaNui AccessPort 1 12-17-2008 03:32 PM
vf 22 map subietech420 AccessPort 0 06-26-2006 07:05 PM
Vf 22 Question and utec Johnnypoofies Engine Management & Tuning 9 03-30-2006 02:11 PM
Need help tuning VF-22 map bhkim126 Engine Management & Tuning 2 11-17-2003 08:58 PM
