Old 07-26-2003, 10:19 PM   #1
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Default EGR malfunction code
'98 2.5RS. How does the ECU determine there is an EGR malfunction? Scanning P0400; no other codes. What sensors detect this condition? Thanks
hossak8 is offline   Reply With Quote
Old 08-14-2003, 12:07 AM   #2
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
keep those replies coming.
Old 08-14-2003, 12:35 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
There is no specific sensor that monitors the EGR. The ECU will check for changes in vacuum and/or 02 readings when it operates the EGR, and if it doesn't see the change that indicates the valve is operating properly a code will set. If you have this code by itself your EGR valve may have failed or the passages may be clogged.
Old 08-14-2003, 09:30 AM   #4
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Thanks Mulder. The engine I have in my car is a 2.5 from Japan, and has no EGR port in the head. I had to use my original intake manifold, and have the port plugged. Is it possible to plug vaccum lines in order to fool the ECU? If so what lines could I eliminate without messing anything else up?
Old 08-15-2003, 08:43 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
I don't think you can fool the ECU because it is looking for changes in sensor signals when the EGR operates, and I don't know how you would fake that.
For starters you should get the engine manual for your car and find out exactly what parameters are required for that code to set.
Old 09-20-2005, 03:08 PM   #6
rogue
Bonkers status: Clonked
Super Moderator
Member#: 7977
100% Abuse
It's the bump from Hell, cuz I searched!
I have, basically, the same problem... new heads on an EJ22 that don't have an EGR port, and I've just closed up the port on the intake manifold for now... but it means I throw a CEL after a while.
Do I have to bore into the block to fix this? Can I tap off the exhaust somewhere?
rogue is offline   Reply With Quote
Old 09-20-2005, 03:52 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
You can actually just tap the intake pipe that runs from the airbox to the TB - try to find an airbox from a 1.8 Impreza with the hole pre-drilled in the box for just such a hose.
jamesfacts is offline   Reply With Quote
Old 09-20-2005, 03:55 PM   #8
rogue
Super Moderator
Member#: 7977
100% Abuse
Tap that... to the EGR port on the intake? How will that work? It's all just intake air...
Old 09-20-2005, 05:36 PM   #9
jamesfacts
Member#: 51282
98 RS
Right, the sensor just wants to see some air under pressure.
Old 09-20-2005, 06:35 PM   #10
rogue
Super Moderator
Member#: 7977
100% Abuse
You crafty little dickens
I'll try that, definitely easier than messing with the exhaust.
Old 09-21-2005, 10:04 AM   #11
jamesfacts
Member#: 51282
98 RS
Yup, this is what we did with my buddy (drewdogg)'s swap from a newer EGR 1.8 motor to an older 2.2. Worked out just fine.
cam malfunction code? bandit_2017 Factory 2.5L Turbo Powertrain 0 06-08-2009 02:40 PM
EGR 546 Code 02WAyGONekid Factory 2.0L Turbo Powertrain 4 05-15-2009 05:24 PM
P0400: EGR Malfunction update gathermewool Service & Maintenance 3 01-08-2009 03:26 PM
Thermostat malfunction code notraceready Factory 2.0L Turbo Powertrain 3 01-03-2008 12:30 PM
O2 Sensor Malfunction Code DeusExMachina Normally Aspirated Powertrain 3 11-22-2002 12:31 PM
Message Board Statistics All times are GMT -4. The time now is 12:18 AM.
