Old 07-26-2003, 11:45 PM   #1
scoobin'
Member#: 14754
02 WRX(X)FXT(X)
08sti, 11outlander, 03evo
Default no boost...oil in intercooler...HELP!!!
i'm not boosting anymore! i came home from work one day and the car drove fine...i drive again 20 mins later and it's not boosting at all...i checked all the lines and everything looks normal and intact...so today i take the intercooler off only to have about 1/2 a cup of oil spill out of the opening that connects to the manifold...then i set it down and take off the Y pipe and another 1/2 a cup of oil leaks out...i know it's normal to have oil in there, but that much? so i bought some brake cleaner and cleaned it out and it's drying right now...has anybody else experienced this, or have any idea why this is happening?
i'm thinking there was too much in the intercooler which was clogging the air flow, prohibiting any boost...my friend said he had the same thing happen to him with one of turbos in his vr4...his second chamber in the turbo went bad, but he had a number of things happen that lead to this like whining noises and bad smoke...i've no warning signals at all...no sound, no smoke, no signals...i really don't want to take the turbo out and get it rebuilt
i'm running a vf30, turboback exhaust, boost controller set @ 9psi...stock fuel sys
can anybody give me any insight or any advice? i need boost!! i'm like an addict feening! also, does anybody know if IHI has a warranty on their turbos? does anybody know IHI's website?
scoobin' is offline   Reply With Quote
Old 07-27-2003, 01:38 AM   #2
wrx320
Member#: 28631
2002 WRB wrx wagon
AVO stg I,II Shiv ECUtek
I am about 99.9999% positive you don't have a warranty on your IHI turbo.
On another note, do you have an oil catchcan? If not, one may help keep your oil pooling in the can instead of your IC. Whether you do/don't, if the turbo seal is shot you will not avoid oil in your IC.
wrx320 is offline   Reply With Quote
Old 07-27-2003, 03:01 PM   #3
mkultra69
Member#: 34402
2002 WRX AP stg 2+
WRB 4EAT and proud of it!
The oil in the ic might be the problem, but since you have it off and the cars just sitting there might as well take the turbo heat sheld off and check the waistgate. If its stuck open youll get no boost at all.
mkultra69 is offline   Reply With Quote
Old 07-27-2003, 07:00 PM   #4
scoobin'
Member#: 14754
02 WRX(X)FXT(X)
is the rod connected to the wastegate suppose to pivot or move in any way?
Old 07-27-2003, 07:39 PM   #5
mkultra69
Member#: 34402
2002 WRX AP stg 2+
You should be able to move it by hand, if you cant that might be the problem. Also what kinda downpipe do you have, if its one that has a divider for the waistgate gas, the flaper might be stuck on it.
Old 07-27-2003, 08:30 PM   #6
scoobin'
Member#: 14754
02 WRX(X)FXT(X)
i tried moving the rod the wastegate and it doesn't budge...i put the intercooler back on went for a test drive...one pass down the road and it's still doing the same thing - no boost...after a couple mins of driving, it starts boosting, but not normally...it sounded like a high pitch whistle (like a hydrolic sound) and it felt like it was being held back...so i think ok, we're getting somewhere...i turn off the car to get some gas and when i start driving again, it goes back to not boosting...i'm figuring something is definitely wrong with the wastegate...??? i have an hks downpipe...i don't think that has a splitter...i'm going to take the turbo off tomorrow and take a look inside...if i can't find anything wrong, the stock turbo's going back on
Old 07-27-2003, 08:49 PM   #7
V REX
Member#: 11102
02 WRX,05STi sold
B5 WB Nogaro S4
I had a problem with the car not boosting at all, the gauge would go up to zero and then stop. I pulled off the downpipe and checked to see if the turbo wheel would spin freely and it was stuck. So, I had to pull out the turbo and there was some type of hose clamp stuck in the tubine wheel on the exhaust side. I just spun it a little and it feel back into the turbo.....then just turned the turbo around and it fell out.
So, check the wheel and see if it spins freely. If it does then I would think it has somehting to do with the boost control.
Good Luck
V REX is offline   Reply With Quote
Old 07-28-2003, 10:13 AM   #8
vile
Member#: 32371
'02 t-rex wagon
platinum
sounds like the oil seal on your turbo could've blown....if you have your stock turbo, that's a good way to trouble shoot and narrow it down to your turbo
put the stock back on....and take a close inspection of the vf30
vile is offline   Reply With Quote
Old 07-28-2003, 10:51 AM   #9
scoobin'
Member#: 14754
02 WRX(X)FXT(X)
what actually causes the oil seal to blow?
Old 07-29-2003, 07:29 PM   #10
scoobin'
Member#: 14754
02 WRX(X)FXT(X)
well...i took the vf30 off and i tried spinning the compressor wheel and it turned pretty roughly, especially compared to spinning the stock turbine...it spins, but i can definitely hear rubbing...so i put the stock turbo back on, and i'm going to have to take the vf30 somewhere to get it looked at...
after i got the stock turbo on and started driving...i noticed that turbo whine was alot higher pitched than i remembered...i hadn't driven the car with a catless turboback with the stock turbo though...is that normal with a catless turboback exhaust with stock bov and stock turbo??
Old 07-29-2003, 08:38 PM   #11
burt_poppenga
Member#: 16442
2004 STi
I noticed that I could hear way more turbo 'noises' after I installed my APS turbo back exhaust (with the stock turbo).
I did some checking around, folks said that is normal.
burt_poppenga is offline   Reply With Quote
Old 03-03-2005, 12:42 AM   #12
navyissuesuby
Member#: 80249
2006 WRX
CGM
Yes that is perfectly normal. I have that exact settup and i can here the turbo spool alot. It is a very high pitched wining sound.
navyissuesuby is offline   Reply With Quote
oil in intercooler maybe from synthetic oil? peonslayer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-31-2006 06:38 PM
oil in intercooler piping.......need help jriggs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-25-2004 12:23 PM
Overfill oil = oil in intercooler GravelRash Service & Maintenance 5 10-21-2003 12:23 AM
oil in intercooler pipes? vadhaspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-20-2003 12:55 AM
Oil in Intercooler Rich King Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-05-2002 10:01 PM
