Old 07-27-2003, 02:07 AM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Hesitation/shudder problem dealing with a P0170 (fuel trim malfunction)
This does not pertain to the typical clutch shudder problem most everyone with a pre 02 RS gets, but it seems to do with the exhaust. I have a wrapped borla header, HKS sport cat back, and I recently added a Random Tech high flow cat. I put it on a month ago then went on vacation, and now pretty much in between 1500 rpm and 2800 rpm, when I try and shift driving normally it shakes like all hell to the point where it seems like I might almost stall if i dont keep it above that 2800 rpm. It also bogs heavily if the throttle is anywhere below 20 % in the 4th or 5th gear. I'm uprgrading the clutch and flywheel regardless very soon, but I doubt it will fix this problem. Has anyone encountered a similar problem after putting on a high flow cat on or possilby give me some advice on how to fix this problem.
AustinSTi is offline   Reply With Quote
Old 07-28-2003, 12:10 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
My car ran like crap when I had a bad 02 sensor... a new cat maybe had some stuff in it, and it caused your 02 to die?
I don't know just a guess. Always good to make sure it's not the basics... When was your last full on tune up? plugs, wires, air filter, fuel filter?
AO
m750 is offline   Reply With Quote
Old 07-28-2003, 03:23 PM   #3
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
yesterday I cleaned the air filter and tommorow I'm gonna get an oil change. Not sure if that will fix it, but if is indeed a bad o2 sensor, how much will one of those cost. Isn't there some sort of o2 cel fix for the random tech as well?? where would i get that?
Old 07-29-2003, 02:12 AM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Old 07-29-2003, 05:41 PM   #5
m750
Member#: 2278
8Sti | 07 allez
White | Comp
air filter and oil change, unless terribly over due shouldn't cause this problem. I'll repeat my suggestion, plugs, wires, fuel filter if they haven't been done in 20 or so k. The o2 sensor isn't a bank breaker, I think it's around 125 or something. But I'd recomend you do that first, so, you are at least in proper tune.
AO
Old 07-29-2003, 08:14 PM   #6
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
got the cel pulled, turns out it is a P0170. I checked the CEL log thread, and it wasnt even listed. Its a fuel trim malfunction (bank 1). Anybody know what is necessary to fix this problem??
Old 07-29-2003, 11:36 PM   #7
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
IIRC the O2 sensor is about 60 bucks check here for more info.
http://www.scoobymods.com/forums/sho...?threadid=1039
Does it sound like there are any leaks in the exhaust? if you need a shop I know where one is but its a bit of a drive. PM me if needed.
Poppa smurf is offline   Reply With Quote
Old 07-30-2003, 01:34 AM   #8
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
ok, so with the P0170 (fuel trim malfunction), all I'm going to need to do is to buy a new o2 sensor?or will I need to buy a new fuel filter as well?
Hey Poppa Smurf, If it is just the o2 sensor that needs replacing, I might have to take you up on that offer for the install, and to check for leaks at the shop you know. If its MD I'll try and coordinate a date thats good for you, and for Steve (tai chih) cuz he lives up in MD somewhere, and I'm gonna have him install my clutch and flywheel...hopefully we could do it on the same day.
Old 07-30-2003, 03:55 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ive heard something about a problem w/ grounding around those rpms
i heard this back before i knew much about scoobs so i dont remember really what it was about but this guy that told me had huge new grounding cables on his car and was ranting about how big of a hessitation is caused w/o them
maybe that will help
alex
Old 07-30-2003, 04:53 AM   #10
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
sometimes when accelerating in 3rd i feel a slight hesistation...actually all the time... >:T
dRu888 is offline   Reply With Quote
2007 STI & WRX with Hesitation/Gearing Problems? squashman News & Rumors 277 09-03-2007 02:10 AM
Question on clutch shudder problem with 02 WRX x Neo x Transmission (AT/MT) & Driveline 4 10-13-2003 11:24 PM
So What's the Deal with the Cold Start Clutch Shudder? Flea New England Impreza Club Forum -- NESIC 14 07-17-2001 10:16 PM
OK, what's the deal with the shuddering clutch? Mike Smith Normally Aspirated Powertrain 10 07-17-2001 06:05 PM
I have the terrible Cold clutch shudder problem with my 2001 RS scootr Normally Aspirated Powertrain 16 12-21-2000 11:53 PM
