Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-27-2003, 01:23 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default how do u take off front axles?
I know theres a ping type of deal that u have to take out to get them out but how do u take out the pin it wont move in eather direction we tried pulling it and pushign it out with a screw driver and hammer doesn't work help mee
scobaru is offline   Reply With Quote
Old 07-27-2003, 02:09 AM   #2
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
special tool nocks them out but I never used it. Just use those little octagon things. Get a size that will fit in there and hit the edge of pin and knock it out with hammer. They are big pain in ass and I hate them.Good luck. They can come out either direction and are like a big mouth (teeth) that spreads open when inside axle.
AWJunkies is offline   Reply With Quote
Old 07-27-2003, 10:09 AM   #3
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Just use an appropriately sized flat-head screwdriver, and stick it into the side that doesn't have a little countersunk hole around the pin. Tap it nice and hard with a mallet a couple of times, and it'll start to move, and pop right out. You might want to try spraying on some PB Blaster or similar penetrating lubricant to help get it out.
/Andrew
Kha0S is offline   Reply With Quote
Old 07-27-2003, 01:00 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
A punch works as well.
-Jon
Old 07-27-2003, 04:06 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
yeah, i used a punch to do mine. it works really well when you put the pin back in if you have the right size punch, cause the pin will sit right on the tip of it. if your pins crack or anything, make sure you replace them. broken axle pins are no fun. and just like Andrew said, hit the pin out of the sunken hole and back in the way too. make sure your the teeth on the axle are lined up right when you put it back on too. if they dont line up, rotate the axle 180 degrees. hope that helps.
Brent
scoobyimprza is offline   Reply With Quote
Old 07-27-2003, 08:07 PM   #6
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The FSM reccomends using new spring pins whenever you do axles, and I'm inclined to agree... they're like $0.97, and pretty fundamental to any drivetrain work.
/Andrew
Old 07-27-2003, 09:31 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
A punch works very well, and you don't need to buy new pins because you don't screw them up like you can with a screwdriver.
Old 07-28-2003, 08:37 AM   #8
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Regardless, the FSM states to use fresh spring pins, whether you use the ST, a punch, or a screwdriver.
/Andrew
Old 07-28-2003, 08:40 AM   #9
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
yeah, i'd replace the pins. since they are cheap, and also, its better safe than sorry
Brent
Old 07-28-2003, 01:38 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Buy the pins and then tear into it. If they don't get damaged, don't replace them. They WILL get damaged if you don't have extras though; guaranteed.
-Jon
How do I take off the front bumper/grille? lawn boy Interior & Exterior Modification 15 08-09-2005 02:06 PM
how do you take off/ put on a front bumper on a wrx? Handsdown Interior & Exterior Modification 7 07-26-2004 12:19 PM
How do I take off the front grill? redforester Forester Forum 3 12-10-2002 06:18 PM
How do you take off the front grill on a MY99 RS Cofusion Interior & Exterior Modification 2 03-22-2002 02:42 PM
how do you take off the front bumper? phatroksek Newbies & FAQs 2 11-25-2001 10:07 PM
