Old 07-27-2003, 07:07 AM   #1
JTAM128
Member#: 40191
$400 beater CRX Si
Default Question about intercoolers???
I always wondered about spraying your intercoolers... I like the stealth look by spraying a FMIC flat black... But does this effect performance??? Please explain why and give support...
JTAM128 is offline   Reply With Quote
Old 07-28-2003, 05:13 AM   #2
Digital_Bath
Member#: 37703
2000 Impreza 2.5 RS
Nope, purely cosmetic. Spraying your IC black may even make it work less efficiently when the sun is bearing down on it (saying as black absorbs far more energy than the bare, silvery metal).
Digital_Bath is offline   Reply With Quote
Old 07-28-2003, 09:50 AM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
You may want to check around. Sompanies (APS, MRT I think) sell FMIC's that are black. It is much harder to tell they are there.
Graham
Graham is offline   Reply With Quote
Old 07-29-2003, 06:44 AM   #4
JTAM128
Member#: 40191
$400 beater CRX Si
Thanks alot for the replys guys... But i would love to hear peoples thoughts about this situation... Personally, i rather have a stealth FMIC... But thats further down the line of performance needs...
Old 07-29-2003, 09:03 AM   #5
Turismo
Member#: 40800
2005 MY06 Hatch
Ice Blue Metallic
If you want the stealth look you will definately achieve this. I would think that direct sunlight on your intercooler would be unlikely if your intercooler is recessed. If you are really worried about performance losses due to the color black then simply install a waterspray kit on the FMIC.
Check these pics out below, this is Ford's new XR6 Turbo with factory black 'stealth' intercooler.
One more pic with a beautiful harbour view!
Turismo is offline   Reply With Quote
Old 07-29-2003, 01:08 PM   #6
SubaFastR
Member#: 5786
There is a special black coating that can be used to make the intercooler even more efficiant. It isn't simply black spray paint, it's special.
SubaFastR is offline   Reply With Quote
Old 07-30-2003, 02:15 AM   #7
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
look here this is exactly what you want.
Nate
NateDogg is offline   Reply With Quote
Old 07-30-2003, 04:23 AM   #8
SubaFastR
Member#: 5786
No, that's nice, but there is a special coating that actually helps pull the heat away
Old 07-30-2003, 07:34 AM   #9
Tats
Member#: 5692
WTF? YES! I am
better than you!
Swain does it.......from piston coatings to intercooler and header coatings
http://www.swaintech.com/race.html
Tats.
Tats is offline   Reply With Quote
Old 07-30-2003, 08:04 PM   #10
JTAM128
Member#: 40191
$400 beater CRX Si
Thanks alot guys...
Old 07-30-2003, 08:17 PM   #11
SubaFastR
Member#: 5786
Tats.
I couldn't find an intercooler specific one, but BBE Heat Radiating Coating sounds like the one.
Thanks!
Kevin
Old 07-31-2003, 07:32 AM   #12
Tats
Member#: 5692
WTF? YES! I am
better than you!
I believe that's the one...but you can call then and jusy tell then what you want it for and they'll help you out. Nice guys.
Tats.
Old 07-31-2003, 01:21 PM   #13
SubaFastR
Member#: 5786
coolio
Question about intercooler function.... J. Steinbeck Newbies & FAQs 11 03-14-2008 08:20 PM
Question about Intercooler HondaDestroyer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-07-2006 03:23 AM
AP question about intercoolers soobturbo Engine Management & Tuning 16 09-15-2005 10:19 PM
A question about turbos and intercooling kattz General Community 21 07-19-2005 01:21 PM
Questions about intercooler spray juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-17-2002 02:25 PM
