Old 07-27-2003, 11:08 AM   #1
WrcSpeed
Member#: 33840
2003 Impreza TS
Default Intake mod
Hi I wanted to modify the stock intake to make it a bit better until I can muster up the cash for a cobb.
I have 4 pictures in the photo album below.
http://public.fotki.com/WrcSpeed/subaru_intake/
Can anybody tell me what the big round container(pic 3) is for and the other angled small one also(pic 4)?
I suspect just for water ingestion protection, but 3 different containers for water (long one also pic 4) ??? Can any of these be removed and plugged up?
Basically I want to make the intake like a PDM-racing style and give it more flow.
Thanks!
WrcSpeed is offline   Reply With Quote
Old 07-27-2003, 12:35 PM   #2
HondaH8er
Member#: 3097
2000 2.5RS Coupe
Silverthorn Metallic
Those containers are more for resonance than anything else. in other words, they tune out a lot of the intake sound for a quiter engine. Should be no problem at all to remove or block them off, as I'm sure you've noticed that all the aftermarket intakes have nothng like that on them. My GanzFlow is just a tube from the fender to the airbox, are is the Cobb and PDM. You might be better off waiting and getting an aftermarket intake, though, instead of modifying your stock intake, just in case you ever need to put the stock intake back on. That's what I did, and it's a good thing, too, as I have to run my Rally-X's in Open class with the Ganz intake, but Production GT with the stock intake. Definitely glad I kept the stock tubing!
HondaH8er is offline   Reply With Quote
Old 07-27-2003, 01:45 PM   #3
WrcSpeed
Member#: 33840
2003 Impreza TS
Well the big container just clips on and off. but the smaller one has some sort of rivet on it.
I will probably just block off the big one and see the effect. I'll do something temporary that holds on with tie-wraps or something.
Old 07-27-2003, 08:56 PM   #4
WrcSpeed
Member#: 33840
2003 Impreza TS
Removed the big container that is linked to the intake and plugged it. I went for a couple of accels and i can definitely see a difference, there's a little growl that was not there before.
For what it takes in time it's worth it. Can't say if it made a improvement performance but it sounds faster
Old 07-28-2003, 03:25 PM   #5
Imprezive2002
Member#: 18872
2002 Impreza
this is the one im selling gives more performance and sounds real nice i ended up buyin a more expensive one throw me an offer its still pretty new only used for a month take a look and get back to me thanks Nick
http://www.digitoma.com/aem.jpg
Madchill@optonline.net
Imprezive2002 is offline   Reply With Quote
Old 07-28-2003, 06:13 PM   #6
WrcSpeed
Member#: 33840
2003 Impreza TS
Thanks but i'm saving up for a better one as well.
Old 07-28-2003, 10:01 PM   #7
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
I've experimented a little with this myself. So far, it seems that the best thing to do is just remove the big 'box', and leave the rest. Taking more away tends to make the engine lose bottom-end because of too much air getting in. Remember that N/A engines like to be 'tuned', or have a certain balance in regard to intake/exhaust flow.
Anyway..... I felt that removing the big box smoothed out the mid to upper end, while retaining the low end. Gives a nice growl at WOT also. Gas mileage didn't seem to be effected much either - still get 26-28mpg.
Plus, it's a 'free' mod!
Subasaurus Rex is offline   Reply With Quote
Old 07-28-2003, 11:25 PM   #8
WrcSpeed
Member#: 33840
2003 Impreza TS
Free is good
Just curious, what did you use to block the hole left by the big container?
Old 07-29-2003, 11:16 AM   #9
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
Didn't cover the hole with anything. Lets more air in that way.
Old 09-18-2003, 04:40 PM   #10
hunts
Member#: 32198
MY13 Impreza Limited
5-door hatchback
Subasaurus Rex: I took the "big box" but had it plugged up. Definitely a little bit noisier than stock at WOT. I was wondering if you had any problems with yours since you didn't plug up the hole, eg. water ingestion?
We're gonna get hit with what's left of Hurricane Isabel tomorrow, so I don't think I'm going to experiment without my plug just yet. :P
hunts is offline   Reply With Quote
Old 09-18-2003, 05:07 PM   #11
impreza99obs
Member#: 42623
1999 Impreza obs
dump question, how do you take it off?? how many bolts??
impreza99obs is offline   Reply With Quote
Old 09-20-2003, 08:07 PM   #12
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
I regularly get email from MRT (mailinglist) and not long ago there was a section on removing the 'air intake silencer' and how it should improve performance. Bloody hell, if MRT says to take it out, then I'm taking it out!
dpjef is offline   Reply With Quote
Old 09-21-2003, 12:06 AM   #13
WrcSpeed
Member#: 33840
2003 Impreza TS
2 bolts and that's it
Very easy cheap (0$) and you see the difference right away.
but I have a 2003 not sure how it is on a 99 like yours
Old 09-21-2003, 12:32 AM   #14
Machine Age Victim
Member#: 29961
2008 BMW 328i Conv.
2001 Kawasaki ZR-7S
too much air is a bad thing?!? I modified mine myself. I'm using a panel filter that uses the front of the stock box and feeds from the hood scoop. That was the best way I saw to get as much air as possible. Still great low-end and strong all the way through. It also knocked 2 tenths off my 1/4 mile time
Machine Age Victim is offline   Reply With Quote
Old 09-23-2003, 03:41 PM   #15
Machine Age Victim
Member#: 29961
2008 BMW 328i Conv.
2001 Kawasaki ZR-7S
no answers to my question?? maybe I'll post a new thread
Old 09-24-2003, 11:08 AM   #16
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Is your OBS MAF or MAP (99 2.2's were 1/2 and 1/2)? If you've got a MAF you need to ignore this entire thread, if you've got a MAP the procedure should be identical... hope that helps.
MAP based Imprezas require the second airbox to compensate for large throttle angles at low RPM. The reason that MY00+ "prefer" Ganzflow/PDM style intakes over traditional J-tube "cais" is for this very reason. If you just take off the back of the box and attach the filter somehow you've done jack squat to improve the intake flow path, you're sucking hot air, and losing low end... the 2/10ths is likely due more to your driving than anything else (how did your 60' times compare).
Old 09-24-2003, 04:50 PM   #17
Machine Age Victim
Member#: 29961
2008 BMW 328i Conv.
2001 Kawasaki ZR-7S
well, it is cold air (well as cold as the air could be after flowing across a dark painted hood in Florida) but it feed from the hood scoop.
my '60 times always stayed consistant around 1.8-1.9, with a reaction time of .580
So I've done nothing to improve the flow of air beacause it's still the same diameter on the MAF?
I also was thinking of putting the back on the box and cut the pipe out ( so there isn't a turn in it) and having the pipe curver around to feed from the hood scoop, maybe an angled opening into the pipe?
oh and how bad is the turbulence over the scoop?? does it get enough ait into it or would a huge, hood-length, NACA vent be better?
Help me choose a silicone intake pipe and next intake mod Red Rocket Factory 2.0L Turbo Powertrain 11 10-18-2002 06:33 PM
did intake mod, but now there's a weird noise! dj722 Southern California Impreza Club Forum -- SCIC 11 05-18-2001 11:10 AM
O2 sensor recall and intake mods vinman Normally Aspirated Powertrain 14 04-24-2001 06:08 PM
Free hp from intake mod John2.5RS Legacy Forum 0 04-02-2000 11:43 PM
Message Board Statistics All times are GMT -4. The time now is 11:45 PM.
