#1 |
Member#: 9378
Vehicle:1991 MR2 Red |
I am pretty sure my driver's side valve cover is leaking a little oil on the exhaust causing the oil smell when I stop the car. I have a 98 OBS.
Can anyone tell me the procedure for replacing the valve cover gasket? I am too cheap to buy the service manuals. How hard is it to do? How long should it take? Thanks, Tim
#2 |
Member#: 9378
Actually, I just changed the oil and looked under there and it looks like the leak is on the passenger side, not the driver's side. It could also be the head gasket after looking at it further. Do the Subaru head gaskets leak over time?
Still need some maintenance instructions for either the valve cover or the head gasket. Thanks |
#3 | |
Member#: 3288
Vehicle:1998 Impreza 2.5RS Rally Blue Pearl |
Clean up the valve cover all the way around on a cold engine with a can of brake cleaner first. Retorquing a leaky valve cover usually doesn't work but it can't hurt at this stage. Use a torque pattern and retighten to 36-48 in/lbs. |
#4 |
Member#: 9378
Albert,
Thanks for the info. I will clean it up and look for leaks. I didn't think there would be much chance for oil in the head. Should only be coolant and air/fuel at the head if everything is working right. I will keep an eye on it. Any advice on a new valve cover gasket??? |
#5 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
The hardest part about replacing the valve cover gasket is having enough room to take it apart!
The valve cover gasket is VERY easy, Remove valve cover Remove old gasket Install valve cover Install new gasket Yours might also have rubber "washers" under the valve cover bolts that need replaced. The valve cover FLOATS between the two rubber parts, realize that the bolts have a torque spec of 14 INCH POUNDS, thats like 4 foot pounds. |
#6 |
Member#: 9378
Not to be a smart ass, but isn't 14 inch pounds equivalent to 14/12 or 1.2 ft-lbs?
2 more questions: It looks like the valve covers have weird star shaped bolts. Will a standard socket work with these? Also, should I drain the oil first before working on the valve covers or will no oil be in there to drain all over my face? |
#7 |
Member#: 24475
Vehicle:1999 Forester L Dirty |
whitet777 - can you take pictures/document the process while you're doing it? I'm interested.
#8 |
Member#: 15543
whitet777:
I dont know what the heck I was writing, now Ive confused myself Ill look when I get home.No need to drain the oil, it drains back to the pan. A small amount will be still inside the valve cover, just put a few paper towels under it. Im pretty sure the bolts you speak of are 12 sided. A majority of tools are designed to fit them, usually you have to specifically get 6 sided. I seriously suggest replacing both at the same time. Even if the other side is not leaking. |
#9 | |
Member#: 3288
#10 |
Member#: 9378
Albert,
I saw your torque pattern, just had to give ciper a hard time with his math ![]() |
#11 |
Member#: 15543
Dang, I thought I was so smart
I didnt even read Alberts post, he isnt supposed to steal my thunder! |
| Thread Tools | |
| Display Modes | |
| Headgasket/timing belt cover oil leak ?'s | badfish1134 | Normally Aspirated Powertrain | 4 | 06-18-2009 08:53 AM |
| Front Cover Oil Leak | cintoman | Service & Maintenance | 1 | 06-01-2007 01:01 PM |
| Valve Cover Oil Leak Question | MiamiLife | Factory 2.0L Turbo Powertrain | 1 | 03-25-2006 03:50 PM |
| What's wrong?? Head cover Oil leak !!(pic inside) | Power_Getter | Factory 2.0L Turbo Powertrain | 3 | 10-14-2005 05:57 AM |
| Valve Cover Oil In/Outs | seven881 | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 04-16-2003 10:24 AM |
