Old 07-27-2003, 02:37 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default J&S Safegueard monitor install help
I have a J&S Safeguard all hooked up and working, but I can't get the dual monitor to work. There are 2 plugs that go into it, 1 goes to the safeguard main unit. The other one has 2 wires that need to be tapped into something, but I'm not sure what. Any ideas where to put these two wires? I tried power and ground, but it didn't seem to work.
lotusTT is offline   Reply With Quote
Old 07-27-2003, 08:59 PM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
The other wires are for the Air/Fuel meter, so they will need to be tapped into an O2 sensor (signal, ground, reference ground.. I think).
You should see the "Knock" portion of the monitor cycle back and forth once when the J&S is powered up.
x99percent is offline   Reply With Quote
Old 07-28-2003, 03:08 AM   #3
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
I found this thread helpful when I installed mine:
http://forums.nasioc.com/forums/show...t=Dual+monitor
Darshu is offline   Reply With Quote
J&S Safeguard MONITOR wanted bdearnley Private 'Wanted' Classifieds 1 04-25-2004 05:30 AM
J&S install help lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-31-2003 12:06 AM
J&S Dual monitor jeffsnyder Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-09-2003 04:54 PM
J&S Dual Monitor voltage question RallyNavvie Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-13-2001 01:10 AM
Anyone got their J&S Duall monitor to work? HRE | giulio Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-12-2001 03:50 PM
