Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 12-26-2005, 04:45 PM   #1
xrturbo
Member#: 86298
98 LGT Wagon
Full WRX driveline & dash
Default best deal on 2.5 rebuild kit??
i just bought a 97 legacy outback wagon for $850 and its in nice condition. the car has been run out of oil and is seized. can anyone tell me where i can get the best deal on a complete gasket kit, bearings, timing belt ect......... for a 97 2.5. i want to tear down the motor first to make sure it isnt trashed and would like to get the stuff after that.
xrturbo is offline   Reply With Quote
Old 12-26-2005, 09:38 PM   #2
vintagemilano
Member#: 92528
2000 2.5RS coupe
blue ridge
If the engine is truly seized, won't turn with a wrench or by hand with the plugs out, it will need far more than a rebuild kit. Would be cheaper and easier to get a good used engine.
vintagemilano is offline   Reply With Quote
Old 12-28-2005, 07:13 AM   #3
xrturbo
Member#: 86298
98 LGT Wagon
i want to tear it down first and see what im dealin with.
Old 12-29-2005, 02:33 AM   #4
JTJ 2.5
Member#: 81572
1968 Subaru 360
2000 RS-H6 Race Car
when i changed the head gaskets in my rs the cheapest place i could find was an internet site www.rockauto.com. it was about $10 less than anywhere i called. the timing belt i got through www.subaruwrxparts.com. they were the least i could find on that.
~jeff
JTJ 2.5 is offline   Reply With Quote
Old 12-29-2005, 02:43 AM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
you should be able to locate a set of bearings and gaskets fairly easily. keep in mind that the rebuild kit is going to be around $225 or more, once you get into the $400 range, you might as well buy a used motor and swap that in. and while you still have a car, tear apart the blown motor and "play" with it a bit.
~Josh~
ballitch is offline   Reply With Quote
Old 12-29-2005, 08:55 AM   #6
xrturbo
Member#: 86298
98 LGT Wagon
so far the cheapest motor i have found has been around $1250
Old 12-29-2005, 06:37 PM   #7
tmeh
Member#: 30800
2000 .7 RS
i'd suggest to find a swap shop, you're looking for what they're removing
tmeh is offline   Reply With Quote
Old 01-01-2006, 08:22 AM   #8
xrturbo
Member#: 86298
98 LGT Wagon
i am going to be rippin this motor down to see whats goin on prob tomorrow, if its salvageable if i do the motor right (all new gaskets bearings pumps ect...) what type of life span can i expect from this thing. i have messed with other subarus but this is my first 2.5.
Old 01-01-2006, 10:08 AM   #9
John*G
Member#: 19562
95 coupe
red
Don't forget to factor in the machine work, the expensive part of a rebuild.
John
John*G is offline   Reply With Quote
Old 01-01-2006, 05:18 PM   #10
xrturbo
Member#: 86298
98 LGT Wagon
the most i should need to do is cut the crank, or does anyone know a good place to get crank kits with matched bearings?
Old 01-02-2006, 02:09 AM   #11
AWDsub
Member#: 56303
2010 Legacy GT
Are just going to build another NA 2.5L? If you are send me a pm because I have alot of cheap parts for a NA 2.5 shortblock with only 10k on them.
AWDsub is offline   Reply With Quote
Old 01-02-2006, 08:16 AM   #12
xrturbo
Member#: 86298
98 LGT Wagon
pm sent
2006 Subaru Impreza 2.5 Rebuilder lalapin Private Vehicle 'For Sale' Classifieds 0 12-28-2007 12:23 AM
Last day to bid on '02 COBB tuned WRX 280+hp show car! best deal on NASIOC/EBay elum Private Vehicle 'For Sale' Classifieds 0 04-21-2005 10:30 AM
Do WRX kits fit on 2.5 RS's??? seesPiKegrind Interior & Exterior Modification 9 01-08-2005 10:27 AM
best deal on Kaminari kit Rentalpillow7 Interior & Exterior Modification 3 01-29-2004 11:11 PM
best deal on stoptech stage 2 wrxlay Brakes, Steering & Suspension 4 09-05-2003 02:30 PM
