Old 07-27-2003, 06:54 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default J&S install help
I tried the Engine management forum, but haven't gotten much of a response. On the J&S Safeguard Monitor, there are 2 connections. 1 goes to the main safeguard unit and the other has 2 wires that get spliced onto something. Anyone know where these 2 wires go? One is silver, the other is black.
lotusTT is offline   Reply With Quote
Old 07-27-2003, 08:43 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
does the J&S come with its own knock sensor? if not im guessing those splice into the factory sensor, silver being the signal and black the ground, but i really have no clue that is just a guess.
no instructions came with it? they have them on the website i believe if you want to look those. http://www.jandssafeguard.com/
hope that helps some
Ben
Old 07-27-2003, 08:50 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
It comes with its own knock sensor, but that's not the problem (for now). The "monitor" is actually a guage that shows when it detects knock. Unfortunately they only have instructions for the main unit not the guage on their website.
Old 07-27-2003, 09:44 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Originally posted by PHATsuby
does the J&S come with its own knock sensor? Ben
Just to clear things up for reference. Some units came with knock sensors (older ones), and the newer ones tap into the stock line of the ecu, thus using the stock knock sensor.
Wedge is offline   Reply With Quote
Old 07-28-2003, 02:18 AM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
thanks for the help Wedge
i didnt see the "monitor" part, this may be a stupid question but does that ecu line supply the power and such? other wise it is prob just illumination power and ground for the guage otherwise i dont know how it would light up when there is knock, that would be my uneducated guess.
Ben
Old 07-28-2003, 08:52 AM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
The knock sensor line will not supply power for the J&S. You will need to tap a wire from the ECU for power. Nothing is easy is it?
Graham
Graham is offline   Reply With Quote
Old 07-28-2003, 11:10 AM   #7
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
well I know its not just power and ground (i tried that.) It looks like i need to tap into one of the O2 wires from the ECU.
Old 07-28-2003, 02:33 PM   #8
Joncas
Member#: 5349
Yes,
Here's what they are.
The little stereo plug whole takes a miniature stereo plug. The outside (shield or silver wire) i would recommend you hook to one of the ecu tie down nuts. I want to say the very tip is 02+ signal (white wire on the cable) and the side is 02- (black wire). No harm hooking it up backwards as they are led's. It requires you to have the cable hooked into the j&s and the j&s properly wired also before the 02 sensor on the monitor will function.
Joncas is offline   Reply With Quote
Old 07-31-2003, 12:06 AM   #9
John at J&S
Member#: 2036
2000 Intrepid
Joncas: Thanks for helping out.
The Black and shield go to ground, and the Clear goes to O2 signal.
If you have a four wire sensor, connect the Black to O2 reference ground.
John at J&S is offline   Reply With Quote
J&S install + Apexi safc II install gto7419 Normally Aspirated with bolt-on Forced Induction Powertrain 0 05-05-2007 11:09 PM
J&S Safegueard monitor install help lotusTT Engine Management & Tuning 2 07-28-2003 03:08 AM
J&S install question Impreza Rider Engine Management & Tuning 26 04-30-2003 11:51 PM
J&S Install- Car Won't Start? Graham Normally Aspirated with bolt-on Forced Induction Powertrain 12 02-26-2002 12:22 PM
J&S Install Instructions Jewbaru Normally Aspirated with bolt-on Forced Induction Powertrain 19 02-22-2002 09:59 AM
