Old 07-27-2003, 07:36 PM   #1
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Default Mechanical Noise Coming from Engine
I have a strage mechanical noise coming from my engine and I cant fidure out what it is. At first I thought it was my power steering pump, but when I turn the wheel the noise doesnt change in volume or intensity. Then I thougt it might me the A/C compressor but when I turn the A/C on the noise doesnt go away. The volume of the noise becomes louder when RPM's increase. I cant seem to figure out what it is. Has anyone had a similar problem? If so, what did it turn out to be? If it matters my mods are COBB CAI, Tanabe Hyper Medallion cat back, 5zigen lowering springs, Cusco Rear sway bar, kartboy short shifter (noise started a couple of days after this was installed), ACT clutch. Thanks for you help.
JewPac42 is offline   Reply With Quote
Old 07-28-2003, 11:48 AM   #2
JewPac42
Member#: 23260
Patr ick Willis
Anyone? Also I am a little late for my 45,000 mile service. Could it just be that I need routine service and that will take care of the noise?
Old 07-28-2003, 11:53 AM   #3
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I would say uninstall the short shifter and see if that clears it up. I installed my Kartboy shifter and bushings and definitely get some gear whine/noise from that.
Jard is offline   Reply With Quote
Old 07-28-2003, 12:19 PM   #4
JewPac42
Member#: 23260
Patr ick Willis
Could you tell where thre noise was coming from? Mine sounds like it is coming from the engine bay and not the tranny. But I will try you suggestion when I get home tonight and post the results.
Old 07-28-2003, 01:24 PM   #5
kickin_81
Member#: 16679
2004 Forester XT
Is it cold there in Alizee's pants? Does it get more quiet as the car warms up? If so, then you may have a defective timing belt tensioner. That's a warranty issue your local Subaru dealer could help you with. I remember my car had a very loud knocking around the alternator area in the winter season. I took it in, and it was fixed at the dealer the same day. I had that happen to me two times already. They said that the first one was a probably a bad part, that's why I had to take it in a year later. Hope it helps.
kickin_81 is offline   Reply With Quote
Old 07-28-2003, 02:01 PM   #6
JewPac42
Member#: 23260
Patr ick Willis
It does seem to get a little quieter as the car warms up. However it is hard to hear due to the intake/exhaust combo. Was this part recalled becuase my warranty is over since it has been more then 3 years since the car was purchased. Also, if this is the problem wouldnt all the belts and tensioners be replaced at the 45,000 miles service? If so, just getting this service would eliminate this noise. But the description of your problem sounds very similar to what I am experiencing, although it isnt really a knocking sound, it kind of sounds like the power window motor noise when I roll my windows down.
Old 07-28-2003, 02:04 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I also have a mechanical noise coming from my engine bay. It changes as I press the accelerator.
It almost sounds like pistons moving inside of a cylinder with 4 valves above each, then some fuel is ignited and the left over gases leave the engine. I also think I hear water being pumped and possibly some oil being pumped. Then at random times I swear it sounds like a fan or two is running.
your post is extremely vague
Old 07-28-2003, 02:06 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Does it go away if you disengage the clutch?
If it appears to come from the front of the motor and nothing but revs effect it, I would say to pull the accessory belts and see if that changes it, and if not... look into a timing belt idler pulley that has gone bad. I had one go bad on me that had the teeth on it and it ended up screwing up far more then the belt (pass. side exhaust valves, pass. side pistons) when it caused the timing belt to jump teeth.
Old 07-28-2003, 02:39 PM   #9
JewPac42
Member#: 23260
Patr ick Willis
8-Complex, no it does not go away if I disengage the clutch. I am not that technical and would worry about screwing a bunch of stuff up if I start messing with belts and whatnot. Also, if this is the problem, doesnt the timing get adjusted at minor/major services (15K, 30K, 45K etc.)? If so, that would fix this if that is the problem.
Ciper- How can I make it less vague? Ask me something you need to know to help diagnose the problem. I tried to be as specific as possible when I posted.
EDIT: Just thought of something else. Could this possibly be an exhaust leak?
Old 07-28-2003, 09:00 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Are you still under powertrain waranty? (60k/5 yrs, IIRC) If so, I'd say bring it in and let them worry about it.
Old 07-28-2003, 09:33 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
Is it a clicking noise, rubbing noise, squeling noise, grinding noise or buzzing noise?
Old 07-28-2003, 09:58 PM   #12
JewPac42
Member#: 23260
Patr ick Willis
I am under powertrain warranty. Do I need to swap out my intake/exhaust?
cipher-a buzzing noise would describe it best
Old 07-29-2003, 08:26 AM   #13
kickin_81
Member#: 16679
2004 Forester XT
If I remember correctly, MY98 Imprezas needs their timing belt changed at 60000 miles; while the newer Imprezas that are SOHC, and isn't changed until ~100000 miles. My point is, your dealer hasn't changed your timing belt. Call your dealer... and it would help to swap the stock parts back on.
Old 07-30-2003, 01:28 AM   #14
JewPac42
Member#: 23260
Patr ick Willis
It is the alternator. Thanks everyone for your help. Do i need a new one or could something on it just be loose?
Old 07-30-2003, 01:51 AM   #15
JewPac42
Member#: 23260
Patr ick Willis
Shouldnt the alternator last more then 45K miles? This seems really strange to me. Would this be covered by my powertrain warranty?
Old 07-30-2003, 02:09 AM   #16
liigod
Member#: 30512
01 2.5rs
black
alternators unfortuantly go out quite often, but its odd at that mileage.
liigod is offline   Reply With Quote
Old 07-30-2003, 11:23 AM   #17
JewPac42
Member#: 23260
Patr ick Willis
I thought so too. Anybody else have an opinion? Since it didnt die it is just making noise, could it be a faulty alternator?
Rubbing noise and tapping noise coming from engine bay. (OPEN TO READ MORE) Soulofdarkness Newbies & FAQs 8 12-19-2005 01:11 PM
Strange noise coming from engine t-rex25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-25-2004 02:27 AM
i have a winiding noise coming from engine teamslow wrx Newbies & FAQs 3 01-14-2003 02:23 PM
Anyone hear a weird noise coming from engine bay in the cold weather? WRXVII Service & Maintenance 1 12-29-2002 06:13 PM
Help!! Strange noise coming from engine 02SilverBullet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-11-2002 08:41 PM
