Old 07-26-2003, 04:30 PM   #1
mike270
Member#: 12863
2002 2.5RS
Default Torque on strut bolt?
I am going to add another ground wire from strut bolt to the engine but I need to know what the torque specs are for either the manifold bolt on the drivers side and the torque for the strut bolts.
mike270 is offline   Reply With Quote
Old 07-26-2003, 09:51 PM   #2
mike270
Member#: 12863
2002 2.5RS
bump
Old 07-27-2003, 06:08 AM   #3
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
joubtt is offline   Reply With Quote
Old 07-27-2003, 10:08 AM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Not sure about the strut torque, but may have a better solution if you haven't already did it. I ran a 27" piece of 6 gauge from the battery down near to where the original ground is near the starter. It is right underneath the vacuum hose running from the brake booster to the intake manifold. It was an un-used 13 mm fine threaded hole that worked perfectly. I used some aluminum tape to protect it from heat for the first 6 inches to protect it from heat.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 07-27-2003, 09:02 PM   #5
Blindeye_03
Member#: 4418
2016 Focus ST
If you are referring to the strut top bolts, they are torqued at 12ft-lbs and +or- 4ftlbs.
-justin
Blindeye_03 is online now   Reply With Quote
How much torque on the case bolts??? w/arp case bolt kit hectowrx Built Motor Discussion 6 10-08-2008 08:55 PM
required torque for sti bolt on bearing bolts? homer09 Brakes, Steering & Suspension 3 03-21-2008 09:28 PM
questions about correct torque on oil drain bolt and tranny fluid bolt... IMPRZME Newbies & FAQs 7 11-14-2004 11:00 PM
Help: Need torque numbers for the strut bolts, brake bolts and lugnuts for wheels Sordid Philosopher Brakes, Steering & Suspension 3 11-22-2002 09:27 AM
uppipe: 26-30 lbs of torque on all bolts? makanouchi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-05-2002 10:32 PM
