Old 07-27-2003, 11:36 PM   #1
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default Tips on Air Temp correction (Utec)
"7. Air Temp. Correction Setpoint is the Intake Air Temperature at which, if exceeded, will result in Fuel Correction and Timing Correction factors being applied to all load points in the fuel and timing maps. You can use this to automatically increase fuelling and/or retard ignition timing as Intake Air Temperature increases. The extra fuel or timing retard may reduce the risk of heat induced detonation"
So we've been having some really hot days here lately in the 100+ areas. Wondering how I can set this up to retard timing / increase fuel when it's hot out to prevent knock.
The value says 0-100 and is defaulted at 100.
So how do I know what to change it to?
MAD REX is offline   Reply With Quote
Old 07-29-2003, 12:17 AM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Old 07-29-2003, 10:20 PM   #3
jlw
Member#: 12654
02 WRX Sdn, 2.5L
Element Tuning GT65r/hdrs
jlw is offline   Reply With Quote
Old 07-29-2003, 10:47 PM   #4
digitaltekniq
Member#: 18029
I have mine set at 95c for coolant and 50c for intake air temp - you need to look at the coolant and air intake temperatures being reported by the UTEC when you were tuning the map you normally run.
digitaltekniq is offline   Reply With Quote
Old 07-29-2003, 10:49 PM   #5
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I got the answer over at wrxhackers.com
"You need to do some data logging on the hot days to see how high the temperatures get. Use #2 logger.
The 0-100 numbers are degrees Celsius.
Just for reference, my settings: IAT=45, ECT=95, 0.2 fuel, 1 timing. Its been hovering around 38C (100F) all month, and I haven't seen any knock."
http://www.wrxhackers.com/modules.ph...ewtopic&t=1204
Old 07-30-2003, 10:05 AM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
For a stock TMIC car with stock cooling system I'll program 96/51/.2/.5 water/air/fuel/timing
For an FMIC stock cooling system car I'll program 96/49/.2/0
For an FMIC colder thermostat car I'll program 92/49/.2/0
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-30-2003, 11:01 AM   #7
digitaltekniq
Member#: 18029
I tuned my car on a relatively cool 85F day to 92c coolant and 42c on IAT. My values are pretty consistent with Jorges, although I pulled a full degree of timing and .5 fuel.
Old 07-30-2003, 03:48 PM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
IMO .5 fuel is HUGE... but hey, whatever works
.5 is an easy .4-.6 AFR depending on injector.
hehe
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 07-30-2003, 04:46 PM   #9
digitaltekniq
Member#: 18029
Hehe, yeah, I'd rather be pig rich than boom
Gas is cheap, engines aren't
Old 07-30-2003, 04:47 PM   #10
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
So I was watching the dashboard and at idle at a redlight the air temps increase a lot. So once it turns green it's going to correct my fuel until the air temps reach what I have it set at right?
It's been a while. Need tips on where to buy Momo Race Air Aluminum shift knob. obyone Interior & Exterior Modification 8 11-05-2006 05:49 PM
Temp correction on a utec wrex03 Engine Management & Tuning 6 04-12-2005 10:19 AM
Any tips on taking off coolant temp sensor? tough location! Max Umbarger Service & Maintenance 0 12-01-2003 02:38 PM
trying to find air temp gauge. before-after intercooler air temp, and two others STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-10-2003 03:38 PM
Help finding Intake Air Temp or Coolant temp sensor jacksonww Legacy Forum 1 08-27-2002 01:42 PM
