Notices
Old 07-28-2003, 10:42 AM   #1
schnell
Member#: 14362
2002 TS Wagon
Midnight Black Pearl
Exclamation Corrosion on my distributor terminals!
I removed the spark plug cables from the distributor to check things out. The little terminals on the block were all shiny but one, which was green/grey with corrosion. I didn't want to use sandpaper or steel wool without checking here first.
What should I do to remove the corrosion, or is it not that big of a deal? Just a little steel wool and then some conductive grease?
Thanks,
Jason
schnell is offline   Reply With Quote
Old 07-28-2003, 11:04 AM   #2
goobie
Member#: 8273
2006 WRX Wagon
That's what I did with mine. Just took some really fine sandpaper Like 400 grit and a little lube to wet the paper and cleaned off the post. Then I put new wires on so this wouldn't happen again.
Chad
goobie is offline   Reply With Quote
Old 07-28-2003, 11:31 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
FYI it's not a distributor, it's a coil pack. Clean it off as suggested and look at the wire that goes on that terminal. If it is corroded as well buy a new set or it will happen again. Keep an eye on it for a while, if it corrodes again the coil will need to be replaced.
Actually, if your car is an 02 this should all be covered under warranty so maybe just have your dealer look at it before you do anything.
Old 07-28-2003, 02:26 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Dielectric Grease
Old 07-29-2003, 10:25 PM   #5
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah, dielectric grease is awesome. Be sure to use some after you clean up the terminal. Its also a good idea to put the stuff on whenever you change plug wires... some come pre-greased, but it doesn't hurt to be safe. Dielectric grease is also great for keeping battery terminals from getting nasty a few years down the road.
ws6fiero is offline   Reply With Quote
Old 07-30-2003, 01:24 PM   #6
Austin
Member#: 7089
2016 STi
Originally posted by ciper
Dielectric Grease
Ditto.
Austin is offline   Reply With Quote
I always have deposits on my positive battery terminal -=C=- Off-Topic 18 09-09-2008 04:29 PM
Corrosion on my dp 904scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-13-2007 11:53 PM
Corrosion on HKS Downpipe? Mr. Mercado Car Part Reviews 7 10-30-2004 04:19 PM
Corrosion on my rim's polished lip from road salt WRmotoX Interior & Exterior Modification 5 03-04-2004 02:20 PM
Cleaning corrosion off my battery Stroke Off-Topic 7 11-05-2003 09:57 PM
