Old 07-28-2003, 01:29 PM   #1
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
Default A/C Removal?
Hey, has anyone removed their A/C? I have a '00RS that is now "off the street" and I am looking to yank the A/C for weight purposes. What I am looking for is tips and/or tricks... I am guessing that I will need a new belt, anyone know which one? Will there be anything I will need to plug or cover? Thanks to anyone that can help me!
Christian
Chin is offline   Reply With Quote
Old 07-28-2003, 01:50 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You'll need to depressurize the system. You can wrap a towel or rag around either the inlet or exit ports on the compressor, then slowly break the bolt loose. If you do this slowly and take proper precautions, it should be fine. Refrigerant on the skin can cause frostbite.
Once that's done you can remove the compressor, evaporator, a/c lines, condensor in ducting.
The a/c compressor has it's own belt so that's not an issue, and you can probably remove the a/c idler belt tensioner.
Legacy777 is offline   Reply With Quote
Old 07-28-2003, 01:52 PM   #3
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
Thanks much! Looks like it may be easier than first expected.
Christian
Old 07-28-2003, 06:02 PM   #4
RawCode
Member#: 3115
2002 Impreza 2.5RS
Of course shouldn't the refridgerant be recycled and not releasd into the atmosphere?
RawCode
RawCode is offline   Reply With Quote
Old 07-28-2003, 06:32 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It is definitely illegal to vent R12 (freon) into the air, may be for 134a as well. As mentioned it's also potentially dangerous.
If the car can be driven at all it should be taken to a local shop that has the proper machine to capture and recycle the refrigerant.
Old 07-28-2003, 06:34 PM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
Take the car to any of the places that say advertise that they service AC systems. They have the machine required to remove the freon from you car safely.
Once you get that done, you just un bolt everything.
Be aware that even with the AC drained there is some gunk in the AC condensor that will pour out if given the opportunity. I dont know what this stuff is, but is like oil or something. You might tape up all the holes where you remove lines from.
You will also need to fabricate some radiator ducting once you get the condensor out. If you dont, it leaves large holes on the sides of the radiators. You car will run slightly hotter since air is flowing around your radiator and not through it. Really easy to do though.
Thats all I can think of.
J
jeffg is offline   Reply With Quote
Old 07-28-2003, 07:05 PM   #7
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
about how much weight does a full A/C removal save?
RokketRide is online now   Reply With Quote
Old 07-28-2003, 08:05 PM   #8
Legacy777
Member#: 4800
r134a is not ozone damaging. His 00 Rs most certainly has r134a.
The procedure I gave may not be the "official" method but it does work when done safely. I've done it.
Old 07-29-2003, 09:46 AM   #9
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
Thanks everyone. I will be sure to weigh the removed parts and post it.
Christian
Old 07-30-2003, 02:46 AM   #10
danci1973
Member#: 19018
1995 Legacy Wagon
Christian
Would you mind sending your lonely, abandoned A/C to me? I'd be more than happy to install it and take care of it...
D.
danci1973 is offline   Reply With Quote
Old 07-30-2003, 04:55 AM   #11
joefocker20
Member#: 13745
2015 STI
I recently removed the ac/ps/emissions equipment from my RX-7, and it equated to a bunch of weight savings, and really cleaned up the engine bay.
joefocker20 is offline   Reply With Quote
Crankshaft sprocket removal as part of camshaft removal jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-12-2005 05:27 PM
Removing heads without removing block phantomsr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-11-2005 08:44 PM
need to remove front bumper to remove a fender? idealrides General Community 0 11-13-2003 03:38 AM
Best rust removal/ remover?? Cusco Service & Maintenance 3 05-21-2003 03:14 AM
removing defi pod -- broken tabs, how do you remove whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-23-2003 01:49 AM
