Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-21-2001, 09:44 AM   #1
JohnWad
Member#: 4768
2002 WRX Sport Wagon
Post Blitz DSBC Setting?
I just got a DSBC and wanted to know what settings for Ratio and Gain everyone is using on their WRXs.
I know that mods, etc. have an effect on the settings, but I just want a base from which to tune from. I am looking to run around 1.0 to 1.05 bar on the highest setting and .85 to .90 bar at the lowest. Any info would be greatly appreciated.
JohnWad is offline   Reply With Quote
Old 05-21-2001, 09:49 AM   #2
JaMa
Member#: 5206
Post
You will see that I have this question as well, in the thread "How Much is Too Much" below - I have been running with a ratio of 50, gain of 25 and no scramble settings. It is too much I think, so I am still trying to dial it in. There are numerous other people on here running these units as well but I am having trouble getting them to respond to these questions. One of the issues is that some of them already have the larger turbos so their boost settings are probably a moot point as their ratios will need to be lower than ours to produce the same psi at the manifold.
I would start at a ratio of 45 with a gain of 10 and move up from there. Then you can set your max boost threshold at 1.10kg/cm2 which is about 15.7 psi and see how you like the car. I personally am going to disconnect my dsbc today and put the stock boost controller back on so I can watch the behavior of the stock electronics before I go any further with programming myself, just to be safe.
Please post back and report on how you do.
Thanks
JaMa
JaMa is offline   Reply With Quote
Old 05-21-2001, 01:31 PM   #3
JohnWad
Member#: 4768
Post
Thanks.. Anyone else out there?
Old 05-21-2001, 05:48 PM   #4
Blugin
Member#: 5270
2008 EvoX MR
Red
Post
I have the SBC-ID which is basically the same thing. I've found that my ideal settings are at ratio 55 and gain 8- anything over 8 on the gain makes too much of a spike for me but I might experiment a little. The more gain you have- the less ratio you should have and vise versa. This setting shouldn't allow the boost to ever exceed 13.9 psi- factory setting.
Blugin is offline   Reply With Quote
install: blitz dsbc Evo-Killa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-13-2002 12:47 AM
Blitz DSBC Install? Alxaguiar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-15-2001 11:21 PM
Blitz DSBC or SBC-iD? jamz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-05-2001 10:02 PM
Blitz DSBC settings MJSpiers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-19-2001 12:08 AM
Blitz DSBC TARMAC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-25-2001 07:08 AM
