Old 07-28-2003, 02:18 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Tapping for oil
i thought i could use this nut from subaru that you use for oil pressure guages to tap for oil, but i can't find the right fittings. how should i get oil then? i know of the allen head bolt on top of the engine. where do i go from here?
Brent
scoobyimprza is offline   Reply With Quote
Old 07-28-2003, 02:47 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
are you doing this for an oil gauge or for a turbo feed line? if you have a kit(i have a ludespeed) it comes with a bolt than goes into that hole and then you just screw another adapter in then the feed line, but the threads into the block seemed a little iffy, luckily i had an extra subaru galley plug that i didnt use for my oil guage and also a 1/8 BSPT to 1/8 NPT adapter that was not being used so i just used those and it screwed together no problems i have to yet to see if it leaks but it shouldnt.
hope that helps
Ben
Old 07-29-2003, 01:13 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
its for a turbo. i have that plug that you used on the hole, its a subaru part. i just can't find any fitting that will fit into it. did you run 1/8" oil line then?
Brent
Old 07-29-2003, 01:47 AM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
yes i do believe its an 1/8 but it may be 1/4, the best thing to do would be to ask Tom at ludespeed cause its his kit if you have to make sure.
Ben
Old 07-29-2003, 09:05 AM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
do you think he might have the fitting i need to go into my galley plug and i can just order one from him?
Old 07-29-2003, 10:36 AM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
i wouldnt think so, it is kind of an unusual part, but you could ask, here is where i got mine from http://www.egauges.com/vdo_acce.asp?...Bushings&Cart=
hope that helps.
Ben
Old 07-29-2003, 10:58 AM   #7
Mancini
Member#: 20726
Here are the parts and part numbers I used.
Subaru Mail Galley Oil Plug, 1102AA210, subaruparts.com
Autometer 1/8" NPT-BSPT adaptor, ATM-2269, summitracing.com
Earls -4an to 1/8"NPT adaptor, EAR-981604, summitracing.com
Then I just used -4an line. Hope that helps.
Mancini is offline   Reply With Quote
Old 07-29-2003, 11:30 AM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
thanks, im gonna check all my stuff out and hopefully getting this stuff ordered on the fly. thanks again!
Brent
Old 07-29-2003, 11:38 AM   #9
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
where would be a good place to get -4 AN line?
Old 07-29-2003, 04:46 PM   #10
Mancini
Member#: 20726
summit, part EAR-303004. That's 3' of it and should be more than enough.
Where to tap for oil pressure gauge? joltdudeuc Normally Aspirated Powertrain 9 04-11-2006 09:46 PM
Tapping for oil wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-08-2003 10:32 PM
Easiest place to tap for Oil Pressure guage. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-13-2003 05:27 PM
tapping for oil temp/trans temp GimpWRX Bay Area Impreza Club Forum -- BAIC 0 11-29-2002 02:38 PM
Where to tap for oil psi gauge? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-12-2001 02:44 PM
