Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 07-28-2003, 04:26 PM   #1
downshift1
Member#: 15607
1996 Impreza
WRX Wagon - It's JDM Yo!
Question Tuning PE 660s : How & Why?
After hearing Nathan and Clark's discussion on another thread on ths, I would like to hear everybody's input and comments on how to do it, how hard it is and if there is a better way. Also any comments on the 800cc's?
Thanks!
Dylan
downshift1 is offline   Reply With Quote
Old 07-28-2003, 06:16 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Pay very careful attention to your tps cross over %.
Getting them somewhat right is easy enough.. but since you go into open loop at either 69%+ TPS, or > 3900 RPM, either one of those conditions will trigger different fueling.
If your still in the 0% column it'll affect drivability... if your in the 10% column (using different fuel values) and still in open loop, then you can all of the sudden dump in fuel (due to the mass MAF voltage change), and you run the risk of partial throttle, low throttle misfires.
whenever you make a fuel change.... don't even bother gauging if it's done it's thing until you've put the car through it's paces a few times.
Whatelse... oh yeah, they're a labor of love, and if you go too nutty on the bottom end you'll have the occasional time where it won't start on a crank for like 10 seconds....
anything else? yeah... they weren't worth my time to tune...
Peace,
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-28-2003, 07:54 PM   #3
dman918
Member#: 11202
2006 STI w/ stuff
Bah. You know you love those injectors, Jorge.
dman918 is offline   Reply With Quote
Old 07-29-2003, 12:55 AM   #4
Tuning Factory Inc.
Vendor
Member#: 3600
It's not so bad. I've tuned many. IT takes some time to street tune it is all. Dropping the % in the 10 column to 30% instead of 60% would work better but would take time to do properly. At 38-60% throttle you don't go into the 10% column but often get significant amount of boost which triggers lean conditions. You can just add fuel at 10% but it may run a bit rich at part throttle. E-mail me if you need more help. I have those in stock BTW.
Tuning Factory Inc. is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 07-29-2003, 03:03 AM   #5
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Axis 2.35L,6-speed,ect
Thumbs up
HEY GOD, How long does it take you around to tune these injectors. Also this may be a stupid question but are the PE800cc injectors any easier to tune??? thanks,eric
BLUETURBOWRX is offline   Reply With Quote
Old 07-29-2003, 10:37 AM   #6
Cacophony
Member#: 213
2004 Mazda RX-8
800cc's easier to tune? Hah!
Notice how much the fuel has to be adjusted to get the 660's to run? It will only be worse when you have bigger injectors and more fuel.
No problems with the 660's in my car.. Motec loves them.
Cacophony is offline   Reply With Quote
Old 07-29-2003, 02:58 PM   #7
downshift1
Member#: 15607
1996 Impreza
So the only problem with the injectors is trying to tune the UTEC around them...
Looks like that nails it, GEMS here I come.
-Dylan
Old 07-29-2003, 03:05 PM   #8
0db
Member#: 33879
Open loop fueling the whole map is so much easier anyway.
0db is offline   Reply With Quote
Old 07-29-2003, 03:08 PM   #9
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Lets not drop this subject. This is the LAST thing hanging in the balance for me to finish my car. Im looking at either the UR low impedance 785cc or the PE 800cc I have a utec and a JDM ra c ecu... I have no problem flashing my ecu to "make" it work with the PE... any more help would be great...I know where most of the local guys stand on this, so looking for some outside views too.
thanks
-nick
Redline8k is offline   Reply With Quote
Old 07-29-2003, 03:19 PM   #10
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Hey nick, did u call turbo XS to find out if the 785's are decent injectors or no. I would like to know what they said if you talked to them.
Yes please dont drop this subject, i need bigger injectors for my set up and dont know what to do. Keep replying to this post cuz im very interested. thanks,eric
Old 07-29-2003, 03:30 PM   #11
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
no I havent, but its not about if the injectors are decent or not more like if the utec will drive the low impedance or not...and work well with my setup...
-nick
I should have time to call them today...
Old 07-29-2003, 04:14 PM   #12
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Sounds good nick, give me a call if you get a chance and let me know what they think about those injectors. thanks,eric
Old 07-30-2003, 01:36 PM   #13
downshift1
Member#: 15607
1996 Impreza
Bump!
Nathan?
Clark?
-Dylan
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 01:14 PM.
