Old 07-28-2003, 03:36 PM   #1
awd4ever
Member#: 31573
I found the
meaning of life!
Default water pump replacement on 97 impreza
Have any one replaced a water pump on a 1.8 - 2.2 engine?
How hard is it?
how much time does it take?
Can it be done in a parking lot?
awd4ever is offline   Reply With Quote
Old 07-28-2003, 05:40 PM   #2
Kurt_W
Member#: 16865
2004 WRX SW
92 SVX Ls-L
It can be done, and it not terribly hard, but it will be time consuming. It's been while since I did mine, and I had the engine out of the car at the time...
I know I had to remove the crankshaft pulley, timing belt covers and timing belt. With the engine in the car, you will most likely have to remove at least the radiator fans and upper radiator hose...it would probably make life easier to remove the radiator altogether (unless you have a 4EAT, which removing the radiator would mean loosing tranny fluid, just one more thing to worry about.) Removing the radiator would also eliminate the possibility of puncturing it while removing the crankshaft pulley. You may also have to remove the A/C and power steering pump brackets as well.
You might as well have a new timing belt and thermostat ready to put in when you do the change as well. Also, make sure you have a vice, press or something similar so that you can compress the timing belt tensioner when you go to reinstall the timing belt.
Kurt_W is offline   Reply With Quote
Old 07-29-2003, 02:48 PM   #3
awd4ever
Member#: 31573
I found the
meaning of life!
can a car drive with a broken water pump? (say 2000 miles?)
is there a sure way to know if pump is dead?
Old 07-29-2003, 06:31 PM   #4
Kurt_W
Member#: 16865
2004 WRX SW
92 SVX Ls-L
I would highly recommend against driving the car with a dead water pump for long distances.
What makes you think that the water pump is dead in the first place?
As for telling whether its dead its kinda hard to tell unless the you dig into it. If it's seized, chances are good the car wouldn't be running very well. If the bearing is going, then it would most likely be very noisy.
Old 07-31-2003, 05:34 PM   #5
awd4ever
Member#: 31573
I found the
meaning of life!
how long do they last?
Water pump replacement at second timing belt replacement? doobie Service & Maintenance 1 10-19-2007 12:12 PM
water pump replacement write up? kid22 Service & Maintenance 2 01-23-2007 05:05 PM
water pump replacement on a 98 2.5 RS scoobysouth Service & Maintenance 5 02-08-2005 02:03 AM
Intimidated by water pump replacement procedure C-daleRidr Service & Maintenance 3 01-09-2004 11:23 AM
water pump replacement? mpreza Service & Maintenance 2 03-19-2003 10:29 AM
