Old 07-28-2003, 04:50 PM   #1
czo79
Member#: 6752
Default What should I lubricate injector orings with?
Hello,
I am installing my fuel injectors (side feeds) after cleaning them, and my book says to lubricate the orings with a light machine oil...does anyone know what exactly I should use? My hardware store was confused by the term. They suggested maybe 3 in 1 or marvel...what do y'all think?
much thanks
Micum
czo79 is offline   Reply With Quote
Old 07-28-2003, 06:03 PM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
I use engine oil 10w30.
Albert is offline   Reply With Quote
Old 07-28-2003, 07:33 PM   #3
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Non-Synthetic
cavymeister is offline   Reply With Quote
Old 07-28-2003, 11:35 PM   #4
TheWeis
Member#: 17939
2002 WRX Sedan
also lubricate new injectors?
TheWeis is offline   Reply With Quote
Old 07-30-2003, 12:03 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Dielectric grease or silicone lube
Tim Sanderson is offline   Reply With Quote
Old 07-30-2003, 12:10 PM   #6
TheWeis
Member#: 17939
2002 WRX Sedan
I installed new STi injectors last weekend, didn't know about lube for them. Is it critical, like should I take them out and lube them, or can I leave it???
Thanks
Old 07-30-2003, 01:16 PM   #7
Austin
Member#: 7089
2016 STi
Engine oil is fine, synthetic or dyno.
TheWeis - no, you don't need to remove them. If they're in and not leaking, you're fine.
The reason to lubricate in the first place is to prevent o-ring damage. It's very easy for one of the injector o-rings to stick and get cut or torn while installing the injectors if they're not lubed just a bit.
Austin is offline   Reply With Quote
Old 07-31-2003, 01:15 AM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Personally I would not use engine oil to lubricate them. It tends to get gummy and attract dirt. It also tends to make rubber brittle over time.
What should I replace my Legacy with? vision.dynamix Off-Topic 27 06-02-2008 02:48 PM
WTB; stock uppipe, and WRX injector orings 2.5 Blue Roo MAIC Private Classifieds 1 04-19-2006 04:18 PM
what should I replace the clock with? JBravo920 Interior & Exterior Modification 34 01-17-2006 02:43 PM
What should the WRX subwoofer come with? gtguy Car Audio, Video & Security 10 03-18-2002 12:10 PM
what kind of lubricant should I use for power windows? yuusaku Interior & Exterior Modification 1 06-04-2001 06:50 PM
