Old 07-28-2003, 04:52 PM   #1
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Default Reaching for the spark
I just got some new spark plugs, went to change them and what to my surprise... they are all the way down there?! I can't reach to the darn things. I can get it with a socket w/ extender if I want to, but tightening on the new ones makes me nervous. Can anyone give me come advice on this.
Thanks from newbie with a scooby.
Brindor2.5 is offline   Reply With Quote
Old 07-28-2003, 06:17 PM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
The plugs reinstall should always be started by hand to ensure you can "feel" the plugs screwing in correctly. Use a sparkplug socket/w extension or slip a piece of hose on the end of the plug so you can screw the plug in by hand.
Don't use a rachet or torque wrench until you are sure the plug is screwed in straight.
The torque is 13-17 ft/lbs.
ps...you can remove the intake, windshield fluid bottle, and battery if it will make the job easier.
Albert is offline   Reply With Quote
Old 07-28-2003, 11:15 PM   #3
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Thanks alot. Yeah I didn't think cranking it in there with the socket was a great idea, glad I asked.
Old 07-31-2003, 01:20 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
DO USE ANTISEIZE!!!! Make sure engine is cold before removing them. If you know this already then my apologies for yelling.
Tim Sanderson is offline   Reply With Quote
Old 07-31-2003, 01:03 PM   #5
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
If it helps, read thru the instructions at Scoobymods three or four times before you do it. Make sure you have all the parts/tools before you start, etc.. I recently did mine (2nd time ever changing plugs, first on a Subaru), and it was painless.
Don't rush the job and it'll be fine.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
What is the number for NGK spark plugs for 98 outback? V6 Outback Forum 2 10-31-2003 12:37 AM
Are these the correct spark plugs for the wrx? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-22-2003 06:48 PM
whats the prt number for the NGK TR7 spark plugs? AndyM Normally Aspirated Powertrain 0 03-28-2002 12:15 AM
('93-'01) Help me/ Are the spark plugs the same for the 1999 rs to the 2001 2.5rsMI Impreza Forum 5 08-26-2001 05:24 PM
('93-'01) Are the spark plug wires the same for the Impreza 1999 to 2001 2.5rsMI Impreza Forum 0 06-11-2001 06:15 PM
